Photoshop elements is very worthwhile.
Is it free?
I spended all my Pesos on tequila, cheap womans and solder.
Better value than the free programs...
dave
Nice try John! Maybe you could trade for Pancakes?
I'll have to "expand" on the size cap a little. Just redid some images in the swap meet this morning. They ranges from 850K to 500K could only get them down to ~140K at stay clean and clear. Photos of circuits boards don't seem to compress well. Still a big reduction, tho.
Is it free?
In that order?
I prefer Preview.app in Mac OSX because I prefer to organize my images differently rather than the iPhoto library scheme but if you use iPhoto to organize your photos it would be more convenient to use iPhoto since you can't easily get at original images without launching it.
On Windows or Linux grab a copy of Google's free Picasa. All the tools you need.
Do a histogram check, adjust if necessary (usually is), sharpen (be aggressive) and then reduce to image size in pixels. Use the "save as" command (to avoid overwriting your original) and save as JPEG. The slider shows you a live preview of the detail you'll get and the final file size it will be.
About a minute of your time.
I've attached an example I made for an eBay auction, 102 kB 800x600.
How to adjust histograms:
Do all adjustments on the original (full size) image, but don't save.
Move the two outside arrows so that they meet the "mountain". Move the middle arrow to reduce shadows and therefore increase shadow detail. Don't move it so much that the highlights wash out (turn white).
Then sharpen aggressively.
Then you can adjust size last.
Then use the "save as" command (NOT the "save" command) so you don't overwrite the original high-resolution image, and use the tools available to reduce file size to your target JPEG size.
Then close the original high-resolution image WITHOUT saving.
This is a very quick routine and doesn't require fancy photo editing software; almost anything will have these tools.
You can see that the photo improved in the second image over the first, just by these two simple adjustments alone; and that's about all you need to do. they're both 76 kB.
You would not necessarily do the same things to photos you intended to print out, but for uploading to a forum it's quick-and-dirty and gets the job done.
and all similar pic links should be automatically intercepted by the Forum software.Ban PHOTOBUCKET !!
Absolutely !!
The pics posted above prove my point.
Andy
Yes I agree. I use it to download and export only. I of course shoot everything at high res and for work shots I only require around 100k so this is an easy way for me, the non-geek type.
I see the OP's rant about Photobucket - I've had an account there for five or seven years (since I was selling on ebay), and all the pics I've put up there are still there. If you're going to display someone else's pics, regardless of where they're from (and it's public domain or reasonable to assume your copying is "fair use"), it makes sense to copy it to your own account rather than hot-link to their pic (for many reasons - many sites/users disallow hotlinking, and some may replace the pic with shameful obscenities when they find it being hotlinked).
But then I read Pano's blog posting mentioned earlier in this thread, and there's a comment:
For resizing I've recently used Gimp - it may be overkill and a steepish learning curve, but I've finally figured out which Special Menu Items to use (select/resize/copy, then create new file from clipboard) for resizing.
which I hadn't considered - this person may never see my pics from photobucket, and I suppose that's a good enough reason to upload/attach pics to posts here on diyaudio rather than use another site.Those on filesharing sites are blocked by the company filters.
- General Interest
- Everything Else
- Pictures -- Why Not attach Them ??
