Pictures of your diy Pass amplifier
Power supply is pretty safe to touch as it is only around 30V, of course 60V across +/-, but still within safe limits :)
Rectifiers are also pretty far back, but I have thought about what happens if you drop your key over them. It has a total of 8 properly sized fuses though :)
Thank you ALL for your KIND comments!
Kiitos!
It isnot apartment but it is F5 :)
Sent from my iPhone using Tapatalk
Another vanilla F5.
Nothing like the monster builds others show but I am pleased with it.
V3 boards from the shop.
LEDs brought to front panel.
Relay for switching on mains power.
Joined 2012
M2 Headamp finally ready
M2-HPA-ww.jpg It took me some months to finish, but finally it's as intended in a nice chassis.
It's a dual mono headphone amp, with the M2 gain stage, with the Diyaudio headphone amp output stage with the Jung/Didden Super regulator boards and not to forget the crossfeed circuit from EUVL from his F5-HA Description V1.4 document.
It was a nice journey back in time, to make my own PCB's, with all the chemicals and so on :D
Lessons learned: design one big PCB with everything on it, connecting all those little PCbs is a lot of work :) It will look neater also.
The Edcor's did pick up a lot of hum from the initially placed R-core transformer. Changing to toroid's and placing them this way, solved the hum problem.
The outputstage has 3.3 Ohm source resistors, resulting in a 180mA bias at 15.0 Volts. Enough to drive every headphone, I guess.
Regulators and output stage generate about 10 Watts of heat each channel which can be easily dissipated by the side panels.
Resulting in a warm, 42 degrees Celsius amplifier chassis...
With the crossfeed and relais switch board, I can select to listen to only the outputstage, outputstage with M2 gain and outputstage with M2 gain and crossfeed.
Off course it sounds very, very nice!
Walter
It took me some months to finish, but finally it's as intended...
Walter
Walter thanks you are incredible talented i admire that super well made diy Hamp
Special congratulations for your self home made boards
