Here's the inside after a ton of wiring--yes, it's a bit busy.
I think you missed a wire there. I just got hungry lol
Yes, don't forget the sauce.
Stateside, it is 1/8" plate for the back, bottom, front sub-panel and the same for the B1. The faceplates are 3/8" 6061 for the F5 and 1/4" for the B1. The B1 sides are 3" extruded aluminum T-track.What are you using 6mm Al plate?
Got the B1 populated and wired. The little 24v. supply needs it's own little box and that will be next.
Here's my F2, now F2-j
I think I'm linking to thumbnails, so if you care to see the larger pics, here's my post from last year when I built the amp.
http://www.diyaudio.com/forums/pass-labs/150652-finished-my-diy-f2-last-night-2.html#post1925588
My F5
I take a guess and construct my f5 with one heatsink and a bunch of spare aluminium pieces and small heatsinks. I can bias it up to 1.3 amp, the mosffet is about 60 c.
An other B1 and F5
After some months of building is this the result.
At a diy audio day in the Netherlands there were enthusiast comments.
Some has already started building
Hi Tosh,4x Zen: Designed in SolidWorks and made on CNC mills at De Anza College, Cupertino in 2007.
very original & impressive...
Side view a little bit unfinished...
Fugly!
Talk about ventilation...
Its an electric cheese grater.4x Zen: Designed in SolidWorks and made on CNC mills at De Anza College, Cupertino in 2007.
Only heaven know
Regards zeoN_Rider
looks very on topic to me
my B1(reclaimed Bogen mic amp case) and F5
jim
Hi Jim
Looks like you create a balance output from the unbalance....correct? how is this done and did the sound quality improve?
Very impressive Tosh! I'm looking forward to what you're sculpting for your F5.
- Pictures of your diy Pass amplifier
