Pictures of your diy Pass amplifier
Joined 2004
This may be viewed as off-topic, but here are a few photos of my Aleph P 1.7.
Scott
A bit messy, I planned to tidy up after final testing...........
However I can't stop listening after 7 months.:D
maybe someday
jim
Only one comment I would make about the wiring is the speaker wire to the speaker binding posts (internal). It looks too light to me. I use the same speaker wire to wire to my binding posts internally as I do to run to my speakers externally.
I use medium guage OFC copper wire. Externally I use four runs of figure eight where each figure eight is treated as a single wire. And I bi-wire.
ZenV4 with Buffer for Blues
I now just have a modified Lightspeed (I call Lightning Thief) as LDR attenuator to control the Zenv4j and Aleph3 in bi-amp. Sounds swell in both music and movies (passed the Avatar bluray movie test:). Difference in gain of the amps are about 6+dB but sounds balanced on my speakers. Differing sensitivities of the drivers or my room probably balances it out...counter-intuitive objectively but is otherwise with my ears. I just went ahead and tried for the heck of it...can't make conclusions with numbers. The MF that I used for preamp before now just sits quietly and listens:D
Your Shti in the box
OK. What's in the box or have I missed something. Please direct me to some links which shows me what is inside.Please.
I've had this F5 going for awhile. FWIW, I recently checked the bias and adjusted it (after 6 months). It was less than .001 DCV out from my original values. The case is a DIY effort. This F5 was built using the CViller boards, Antek 4218 tranny, and the Tech-DIY kits-Fairchild outputs. Heat sinks were from M&M. The Lexan top was an exhibition affair but It's starting to grow on me. I might keep it instead of the metal.
Also, a little B1, cased and ready to populate (I have it basically done except for the electolytics and chassis jacks).
What are you using 6mm Al plate?
