Pictures of your diy Pass amplifier
Here's my diy Sony VFET amp. Burned it in for several multi-hour sessions with test speakers. All is well and sounding great.
- store 4U deluxe chassis
- heatsinks adapted for external removal
- baseplate drilled/tapped - no fiddly nuts!
- wired for easy component removal
- TeaBag 40mm PS + Panasonic TS-HA caps
- Elliott style GLB
- 2x22V 400VA SumR/Primrose shielded transformer - specially wound for Class A
- "neat & tidy" wiring
- matched IRFP240/IRFP9240
- matched 2SJ313/2SK2013
- matched 2SJ74BL/2SK170BL
- Silmic II caps
Many thanks to Nelson Pass and the rest of the "project VFET" team for making all this possible!
BK
Excellent example high quality amplifier DIY.
Smart components choice , clean wiring +
:superman:
Thanks Bk856er for beauty photos
Best regards
To use power thermistor is allway risky if you dont know its behavoir.
for example, it s weak against inrush current after immediately power is turned of. You may have to wait a little for it has cooled.
He is suggesting the Power Thermistor in the main audio ground to chassis connection. This does not pass significant current in ordinary operation.
The only time it passes significant current is if it has to pass Fault Current to PE in the event of some catastrophic mains failure inside the equipment.
A Soft Start in the primary circuit to the transformer is completely different.
