Pictures of your diy Pass amplifier
I don't recommend building something like that. Way too much work. Better to have a conventional case that you can swap boards in and out of... unless you are me! Bound and determined to do it without finned conventional heat sinks. Now on to a balanced Bba3 into F4s. Also without conventional heat sinks. Might employ a power saw this time, though. Yea, that's my favorite Metheny CD. It's just what I happened to be playing right then. Seemed right, since Metheny's a local boy from Independence, Missouri and I'm in Kansas City, 10 miles away or so. Thanks for the compliment!!
I think it looks NASA as well. I'll bet they wouldn't tolerate the weight, heat, or power consumption. It does resemble some of the stuff I've seen at the Smithsonian Air and Space Museum. Needs to be wrapped in crumpled foil, to complete the effect. I should photoshop it into a photo of Mars, maybe with some tank treads on each side. Naaa, I'll just go back to trying to obtain jfets for the BBA3/F4 build.
All done with my F5.
