Phonoclone 3
rjm
Joined 2004
Photos of my Phonoclone 4.6f. Perhaps a fitting way to close out the thread.
Hi RICHARD,
i have buy several year ago the phonoclone.
The R1 mounted is 47Ohm and R2 is 1k; are these specifications that you have recommended for Denon DL103 still valid?
I have also Audio Technica AT F7, i do I have to adjust the values of R1 and R2?
This are the specification the Audio Technica:
Type: Moving coil (MC)
Frequency response: 15 to 50,000 Hz
Output voltage: 0.35 mV (1 kHz, 5cm/sec.)
Channel separation: 27 dB (1 kHz)
Channel balance: 1.5 dB (1 kHz)
Tracking force: 1.8 to 2.2 g (standard: 2.0 g)
Coil impedance: 12 O (1 kHz)
DC resistance: 12 O
Recommended load impedance: Min. 100O (when head amplifier is connected)
Coil inductance: 25 µH (1 kHz)
Static compliance: 35 x 10 - 6 cm/dyne
Dynamic compliance: 9 x 10 - 6 cm/dyne (100 Hz)
Stylus: Nude elliptical stylus 0.2 x 1.7 mil
Suspension wires: Stainless
Vertical tracking angle: 23 degrees
Dimensions: 17.3 (H) x 16.8 (W) x 25.4 (L) mm
Weight: 5.0 g
Many Thanks and happy new year.
Mario.
Thanks! Yeah, I'm trying to avoid loading up the output too much. The OP27 will swing +/-10V into 600 ohms, but I want to be nicer to it than that. The knee of the curve for output swing vs. load is around 1K. Distortion remains low anyway.
So here's a happy medium, 1.21K.
And this is the preamp itself. I built the power supply into the boards themselves, and it's picking up a little hum, which I think will go away with the new feedback values.
rjm
Joined 2004
Hi Chris,
While it's a compact an efficient layout, the close proximity means there is a risk of noise coupling between the AC wires and the audio signals, as well as from the magnetic fields of the power transformer.
I hope you can manage to get the hum down to manageable levels.
RM
