Bernhard said:the 2k7 compensates for the 1mA BPZ output current of the unipolar 1541
Bernhard that means that an TDA1541a does not need it ??
Onno
tubee said:Ok, but still its no harm to read "TDA1541 info" anyway. The 1541 is very sensitive on a proper handling of all his pins
Dear Tubee,
In the "TDA1541 info" is a post from Siu Sin Man Tho
about:
Quote:
Tda1541a info Post #15
hi,
I had some detail TDA1541a info from the philips factory when I design the parallel TDA1541a D/A board.
its a PDF format approx 60~70 pages.
Anyone who had interest pls email to me.
I zip already & will email to him.
hope this can help U.
this is my email.
thomas@diyaudiocraft.com.
thanks
thomas
Unquote.
His membership is disabled and his emailadres does not exist anymore.
Do you or somebody else have that (zipped) PDF file for me available ??
Thanks in advance for looking at it.
Onno
Well, these are 3 IEEE articles. If you need them, send me your Email-adress.
I guess, the Informations found their way into the comercial world:
http://www.6moons.com/audioreviews/abbingdon/abbingdon.html
"We actually analyzed the TDA1541A on an internal circuit level in extreme detail. In the process, we discovered a number of areas where correctly designed external circuitry can help to reduce the difference in linearity between the Crown and standard chips. I hope you understand that I do not wish to cover the exact details in any length. This was a research project that began in 2000 when I had published my 1999 TDA1541 non-oversampling DAC. As a result, I was provided with extensive notes (one very large and thick map of paper) on the internal design of the TDA1541 by a kind engineer at Philips Eindhoven."
Carsten
Carsten
carawu said:"We actually analyzed the TDA1541A on an internal circuit level in extreme detail. In the process, we discovered a number of areas where correctly designed external circuitry can help to reduce the difference in linearity between the Crown and standard chips. I hope you understand that I do not wish to cover the exact details in any length."
And I analyzed so many crowns on a spectrum analyzer in extreme detail that all I can say is:
Hu, hu !
Most Crowns are not any better than any plain TDA1541A, so what difference should be reduced ?
carawu said:Well, these are 3 IEEE articles. If you need them, send me your Email-adress.
Carsten
Dear Carsten
pse sent that file to onnosr(AT)bakker.info
Thanks in advance
Onno
Hi Onno
"I had some detail TDA1541a info from the philips factory when I design the parallel TDA1541a D/A board.
hope this can help U." (...)
Could you send me the file, please? My email is jk(at)auditio.com.pl
Thank you very much.
Hi Onno
hoping too ;
please - include >choky@neobee.net<
- Digital Source
- Philips CD304 MK2 help please
