beamnet said:If your mail prigram can send it, i can recieve it.
if not, i could make you an ftp where you could upload the file
I'd be realllllllly hapy!
Bas
pse send me a email I reply with the file and wait what happens.
Onno
I do have the service manual of the CD304 mkII in pdf
It is 9.8 mb (pse suggest how to get that file to you)
Onno, i am interested in that mk2 pdf, thanks for offering it. Is it possible to put it on a server somewhere for a few days, and send us a link to it? (That's the way a friend of me does when he wants to send me a larger file.)
beamnet said:if i recieve the file, i have an ftp where it can be parked for al long time
Bas
Dear Bas
I have send the file.
If you recieved it well, pse put it on your server.
Best regards,
Onno
Onnosr said:
Dear Bas
Best regards,
Onno
That would be much appreciated. I could use it too, so now i know where it might be found
TIA
All the best
Ebbe
beamnet said:It's there
Am i violating copyrights here? Probably are...
Might be, but i don't think it's a major crime . If that was the case, then people at Sharefx.com would be in big trouble
Thanks a lot for helping, and that goes for Onno too.
Best regards
Ebbe
tubee said:The modded 304 mk2 outperformed it. The CDM1 is not fast, but it took a lot longer time before CD was readed in the DVD.
The servo of the cd304 is slow as is the tray
cd960 is very fast with cdm1.
Onno, I think you need separate caps for each chip
Then its better for the 2nd 1541 to sit on a small pcb. And not to forget feed a 176.4kHz DEM reclock signal to them too.
Bernhard said:Onno, I think you need separate caps for each chip !!!!!
Hi Bernhard
I do not see any reason to use separate caps.
And more it works perfect (IMHO !!)
pse explain why you see it differently.
Onno
Onnosr said:
Hi Bernhard
Onno
If I recall correctly, it does increase distortion in low level, I tried to stack 1541 and there was a problem, at least visible on the analyzer.
Hi Bernhard
By stacking the 1541 did you stack pin 16 and 17 to ?
Stacking pin 16 and 17 gives with me distorsion.
That's why I used separate clock capacitors of 470p and sync the clocks by 100p between pins 16
What IV did you use after stacking.
I use on the cd304 MKII board the original opamps and schematic
only the resistors between pins 2 and 1 of 1k8 is replaced by 1k.
Not replacing that resistor gives with me distorsion
I have seen in the schematic of the MKII that there is a pull up voltage fed to the input pin 1 (NE5532) via a resistor of 2k7 (etc) coming from an 8 volt regulator(7808).
Do you have any clue why Philips made it that way ?
The only thing I can think of is to put the NE5532 in a higher current offset when there is no output from the dac's at all to get less distorsion and a smoother transient.
I still have to try that out by cutting it.
Onno
Pin 1 Word select is also in CD640/660 hooked on PS rail. It has something to do with a DC level on the logic (schmidt-trigger?) input circuitry of 1541. For more info Onno, see also I2S leveler here on diyaudio: http://www.diyaudio.com/forums/showthread.php?postid=366490#post366490
Hi Tubee,
Thanks for replying.
Sorry that I confused you talking about pin 1
In my post about the voltage fed to the input of the NE5532 opamps I mentioned by mistake pin 1 but it is pin 2 from the NE5532's connected to resp pin 6 (AOR) and pin 25 (AOL) from the TDA1541a.
Regards,
Onno
- Digital Source
- Philips CD304 MK2 help please
