Pass DIY Addict
Joined 2000
Depending on output level of the cartridge you are using, you may need to degenerate the jFets in the first gain stage as well. My AudioTechnica 150MLX has 5.0mV output and even after fiddling with R14/R16, it was still overloading and distorting on some LPs. Increasing R21-R24 from 10R to ~22R reduced the gain of the first stage and removed the overload I was getting. I just lifted one leg of the original resistors and added another resistor to the empty hole and connected them in series. A quick jumper will return things back to the original state.
Reducing the first gain By increasing resistor values impairs noise performance. Bedides, the problem is in the second gain stage.
Pass DIY Addict
Joined 2000
This is interesting to know, Jack. With a 5mV output MM cartridge, I was unable to avoid overload distortion through adjustments to the second gain stage alone. Perhaps I need to experiment further. Of course, the other solution is to get a moving coil cartridge as was intended
If you’re clever you can skip the passive RIAA and incorporate it in the second stage feedback loop.
Pass DIY Addict
Joined 2000
One thing is sure, a bipolar SMPS of the proper voltage will be a challenge to find.
Perhaps I should stop searching for one then. LOL.
Perhaps...?
DK shows 52 (dual) +/-24V SMPS in stock.
Unfortunately, you'll need a bit more than that if you plan to use the LMxxx regulators on Wayne's boards.
After building successfully Pearl II phono stage it crossed my mind that I can use another kit to build a Tape head preamplifier for my reel to reel machine. I guess I will have to change loading impedance and replace RIAA correction with IEC(CCIR) equalization. Unfortunately I do not have the knowledge to calculate CCIR equalization. Can anyone help me with that. Maybe Wayne? I appreciate any help.
See this paper:
http://www.nomanlab.com/sale/lim_docs/nab_to_ccir.pdf
My Pearl II project has been on hold for over a year ....life gets in the way some times. Ive been using a Dynavecter P75 III as a stop gap in the mean time. Its OK.
Once I sorted the PSU and spent some time setting the bias (bit of a fiddle) but got it to 5mv on each board.
Plugged it all in and fired up the TT dropped the needle in the groove....didnt sound right at first but after an hour or so everything settled down and it sounds very good indeed. It makes the P75 III sound a bit muddy
A pleased Pearl II builder.
Did anyone by chance save a copy of the chipamp lm3886-manual.pdf?
It used to located about 7 years ago at the link below but it appears chipamp cannot be connected to.
Thanks.
404 Not Found
Thanks.
404 Not Found
- Pearl Two
