If I remember Nelson’s story correctly the ESS company drug policy was “share”.
Jim has sent more kits off to the store and more are in the works. This has proven to be more popular than I expected.
It is a nice phono stage especially with the chassis from Gianluca and the communities design involvement and hard work.
For all lovers of the Cascode, I dare to repeat what I have already said: use GR, dont use BL Grade. You could also try a tiny bit: R2=12.7kOhm and R3=8.2kOhm ... otherwise you may well question the function of Q5 and replace it with a wire bridge. Apart from that, the imponderables with the four favorite jFet are natural.
Please pay no further attention
You could explain that in detail' dear Jim.Will be completely fine, there is literally nothing to worry about.
And which trick leads to it not being noticeable at the end.
If the total current is not really greater than 10mAdc, then you have no problem with the selected k170-BL (and R3<R2).
R1 is 9.1V with Toshiba 2SK170 Bl about 3 mA each fet.
The reason I dared to use 2SK170 BL was because Wayne also did that. Like Wayne I have also 9V across R1 and I use ZTX851 both places and 12 mA in total. If Q5 is saturated or not I did not measure as I did not know it could be a problem. The BL's I used was measured to about 7 mA Idss.
I recommend building the kit exactly as Wayne Colburn designed it, using his exact circuit schematic and his exact component values.
Listen to your pure Wayne-P3 for several weeks. Then, if you still have a powerful urge to tinker with the circuit topology or parts choices, go right ahead. You'll know how the Wayne-P3 sounds, you'll know exactly what you love about it and exactly what you think can be improved. Make your modifications and listen again; has the sound changed? Do you still love what you used to love about Wayne-P3? Did the changes improve what you used not to like about Wayne-P3?
It's quite probable you'll enjoy the Wayne-P3 so much that you cannot tolerate the idea of taking it out of your music system for a few days. So you'll abandon any thoughts of modifications, especially when you consider that (a) after the changes the sound might get worse instead of better; and (b) perhaps you might break something when making the changes.
I didn't know that was tinkering, although I was fearful of frying the 2K209s as I had never done surface mount soldering before. And I had the 2SK170s from John LaGrou, which I thought were appropriate for the circuit.
Even though I am working from home, I had to pull off the cover and measure the voltage across R1...an unfluctuating 8.5VDC. 11 mA.
Wayne has "approved" using the 2SK170BL several times and I also think that when P3 was born it was the intention to have 2SK170 in the kit (but not 100% sure about that but from memory I think Wayne wrote that.....maybe search back in this thread to confirm). Reason that there are not 2 x ZTX851 in kit is because they were difficult to get.
I think you should not do anything at this point other than enjoy the sound of P3.
But interesting to learn a bit more about the cascode circuit.
I was wrong about what will be in the kit from when P3 was born.I built the first version with the SMT 2SK209 and the second ones with 2SK170 through hole parts.
The kits will have the available SMT parts.
If this is the last time you will ever build a phono preamp and you have the engineering skills to redesign the circuit, then go ahead and create/build your ultimate project. If you want to build an excellent-sounding phono preamp now/soon, and can accept that the circuit works with a wide range of devices as initially shown by Wayne, then build the kit as supplied.
Personally, I have never seen anything that was the "best", "ultimate", "final" audio design. Have fun building this, and be confident it will sound wonderful. You can always make changes later.
- Pearl 3 Burning Amp 2023
