I have implemented the 2707 as USB to I2S converter and although I have read some comments, that there will be no improvement, taking a XO clock (tried it or just thinking ?), there is for sure an improvement ! No day and night, but for the money you spend on a XO clock (29 Euro) a very good tweak, worth it....
You can use the 2707 as dac it self, but it is not "high end". ranges like an average CD player, which is better than most sound cards of course. All is relative ... But with the I2S at hand, you could feed any DAC with I2S input (like I like the TDA1543) If you need a master clock signal, indeed, than you have a draw back... The only thing comes to mind, is using another free running clock again and do aysnchrone reclocking....
any way, below is the circuit, so you can have a look how I implemented the 2707.... (page 8 of pdf doc)
Link to Circuits PDF
doede
doede
There studies of the pcm2707 jitter here : http://www.diyhifi.org/forums/viewtopic.php?p=8368&highlight=#8368
- Digital Line Level
- PCM2707, I2S out
