Devil_H@ck said:...., but why would you want to export it as an image? ......
To print/copy the project on another computer with a laserp. if you are using press`n peel or want to use copier to make transparencies for uv expusure.
Chris
You need Adobe Acrobat that comes with Distiller - PDF printer, so you print directly into PDF file.
There are some freeware alternatives - I just downloaded one at
www.acrosoftware.com
Still haven't tried it at home, where I have Eagle installed.
AutoTrax EDA
For those of you looking for software: I built a project recently using AutoTrax EDA (95$). It worked fairly well despite a few oddities and glitches in the software. They have a pin limited demo version. oh, to print for PCB exposure, use the plot wizard. a bit confusing, but will work for pos, neg, etc.
I was building amp circuits using 150x250 mm presensitized boards and used double transparency w/ 300w 90s exposure and standard developer for ~60s, and heated/agitated FeCl etchant for ~5min. 7.40$ for 150x250 dbl sided pcb in qty 10+ from CircuitSpecialists.
Chris
I don't understant your problem
Can't you simply print the image directly on the transparency?
Yes , what was I thinking ??? I` m sorry
But I can't get eagle to make this work.
Printing is ok, ant at the correct size. Bit with colors (tracks in blue and pads in green) of course I want a black and white transparency
But setting eagle's printing to monochrome doesn't work
Chris said:Hi Bricolo
Strange, maybe there is a bug in the eagle software???
Have you tried to cange the default setting on your printer to print only in black?
Hope this may help..
I tryed too, and got a 100% white page
Pcb.......
I just tried to print my board into pdf. It worked just fine!
I used acrobat pro. If you don`t have the software you can try the freeware rendisha suggested.
Re: PDF printing.........
OK, I see
BTW, what does the option "black" on your computer?
Chris said:It should look like this................
OK, I see
Re: Re: PDF printing.........
Prints in black,no color, it`s an Eagle print feature.
Bricolo said:
OK, I see
Re: Re: Re: PDF printing.........
when I use the black function, I got a white page, with only the components names
Printing
Hmm. It`s a bit difficult for me to check the various printing features in Eagle at the moment, since I have no printer at home at the moment. And it been a while since I used Eagle.
But this is what you should see before printing (also try the solid function). Hope this may help....?
Must be something wrong with your software. Using the black-function should give you a nice print to use. Have you tried to make a pdf file of your project?.
Suggestions:
1. Get the latest driver for your printer.
2. Save your project and download the latest the Eagle software from the CAD SOFT site.
Happy diy
Suggestions:
Happy diy
rendisha said:You need Adobe Acrobat that comes with Distiller - PDF printer, so you print directly into PDF file.
I tried with this "PDF Printer", and that works without any problem!
Thanks for the tip!
It seems that there's a problem with my printer's driver.
- General Interest
- Everything Else
- PCB expousre
