The work is done.......
This weekend I tried to develop my first PCB boards using UV light and boards with positve fotoresist. I placed the tube ca. 8 cm above the board and exposed it for 4.5 min (after testing first). And the result was great..................
Happy new year
Happy new year
I have some little problems lately. While the PCB's themselves get better and better, it's the drilling that causes troubles.
When I drill a hole in a small trace, the copper around it gets lose from the board. I didn't use the have this. Could this be because my drill bit is worn down? It's a real pain, because very short traces (eg. between 2 resistors legs that are very close together) almost dissapear from the PCB and I have to bend the legs underneath the board to connect them together that way.
What's my problem?
What's my problem?
Devil_H@ck said:I have some little problems lately. While the PCB's themselves get better and better, it's the drilling that causes troubles.
Hi
What size bits do you use? I use 0,1 to 1,0 mm size. The bit must be centered properly or else the drill hole will be bigger. I also put ordinary scotch tape on the board. This stops the "wandering" of the drill, before it starts to penetrate the surface. I also use a dremel tool for the drilling.
Happy DIY
drill sizes
the problem is that your drill bit may be worn in which case it's heating up the pad and loosening the adhesive which binds the copper layer to the fiberglas. if you find that the pads are disappearing consider drilling before you etch -- as has been pointed out before -- this might result in some of the etchant creeping into the pad and making the hole unpretty -- but you can stop this by applying a little wax or nail polish over the hole.
Re: drill sizes
I also use a Dremel and the bits I use are 0.8 mm which is just right for most parts. I'll try the scotch tape thing. I didn't have this problem 2 weeks ago, only with the last 3 boards I did I had this problem. I made a JLH board 2-3 weeks ago with a new bit I bought then and all holes on it are near perfect.Chris said:What size bits do you use? I use 0,1 to 1,0 mm size. The bit must be centered properly or else the drill hole will be bigger. I also put ordinary scotch tape on the board. This stops the "wandering" of the drill, before it starts to penetrate the surface. I also use a dremel tool for the drilling.
I think this is my problem, however, I only have bought the drill bit 2 weeks ago and have since drilled maybe a maximum of 100-150 holes. Is it normal that the bit is worn out after that? These things cost 2.5€, so I expect they should last a bit longer. Also, are there more than one type of these? So, could it be that I have a 0.8mm drill bit for wood, where I need one for iron?jackinnj said:the problem is that your drill bit may be worn in which case it's heating up the pad and loosening the adhesive which binds the copper layer to the fiberglas.
Low quality drill bits will wear very rapidly. Use only good quality HSS drill bits, or at best - the tungsten-carbide bits specially made for PCBs. These comes with a standard 1/8 inch shaft and fits the Dremel perfectly. They should be appx. 3USD ( or Euros) each,- but beware- they are extremely brittle and breaks easily, particularly with just a twich of sideways pressure. Run the Dremel at full speed and feed gently.
Weird, the store at which I buy them is supossed to only have very high quality stuff. It's in a not so small town (well, for Belgium that is) and it's the only store in the city that has this kind of stuff.
Do you have any idea where I could get those special high quallity drill bits?
This is the stuff you want...
http://www.bungard.de/seiten/m_bfraeser.htm
Or the main page www.bungard.de
Bungard is just one of many..
I know Farnell stocks these drill bits, and ELFA in Sweden, both inside EU..
Try a national search and look for a Belgian rep. for Bungard...
Good luck
Good luck
Also here:
http://www.reichelt.de/inhalt.html?...TART=0;END=15;STATIC=0;FC=30;PROVID=0;TITEL=0
listed as " hart-metall-bohrer"
Thanks! If you say Farnell has them, I'll consider giving th em a call, since they ship for free.
Oh, the Bungard drills, what type do I need if I want to buy them? The hard metal drills?
<- nevermind that question, the other things on the link you gave are not for drilling .
- General Interest
- Everything Else
- PCB expousre
