I was following this discussion, but now I am lost.
I think the problem is that the poster does not know what he/she needs. They don't know the difference between bridged and balanced. They are not the same!
A balanced monoblock cannot remain balanced if one splits the balanced impedance cable into separate Hot and Cold feeds to two separate amplifiers.Hi PA, I can only agree with that
In the documentation there's quite a bit of documentation on possible connections/jumper settings except for the one I'm contemplating. I'd like to use them as balanced monoblocks. Hot to one channel and cold to the other? Could you advise how to do so with the jumpers etc. Thanks!
I think the problem is that the poster does not know what he/she needs. They don't know the difference between bridged and balanced. They are not the same!A balanced monoblock cannot remain balanced if one splits the balanced impedance cable into separate Hot and Cold feeds to two separate amplifiers.
I known the difference between bridged and balanced. Would the amps work if you split the balanced input, into two separate balanced inputs, and see the amp for Balanced Stereo Mode, and then bridged the two stereo outputs into a single speaker input? Like they do with multiple power amps in PA systems. Would Impedance be too low, and would the chip remain stable?
And the impedance difference between the hot and cold sides of a balanced cable can be delt with split into two amps, It's not possible with the stock build of this amp, but could be compensated for by tweaking some of the components.
As per nthall; I wonder if it is possible to use both channels (one amp, mono block) with one balanced input and driving one speaker. I don't know how to explain it any simpler.
You are using speakers with regular speaker wire connections correct?
Yes, correct.
It doesn't seem like it would be a problem to me then. Unless it causes issues with the chip, but I don't know enough about them to answer that question.
Thanks, appreciate you hanging in there!
No problem. I'm sure someone will give a vague response, about my lack of knowledge soon enough.
Hi hfxrzw,
Maybe try this,
Set the jumpers on JP1 for single ended non-inverting,
From balanced connector: Hot to JP2(+), cold to JP3(+), Ground to JP3(G)
Output: output closest to the JP5 stencil goes to speaker(+)
output furthest from the JP5 stencil goes to speaker(-)
I've used this type of configuration on previous lm4780 balanced input/bridged output mono amplifiers. The difference is this one has an opamp input section.
Just trying to help out
Maybe try this,
Hi
Any replacement for
Mouser Part #:
511-4020
Manufacturer Part #:
HCF4020BEY
Manufacturer:
STMicroelectronics
Description:
Counter Shift Registers 14-Stage Binary Cntr?
Maybe
HCF4060YM013TR?
Thank you!
Any replacement for
Mouser Part #:
511-4020
HCF4020BEY
Manufacturer:
STMicroelectronics
Description:
Maybe
HCF4060YM013TR?
Thank you!
I've been thinking about adding two more to my order.
I just added two more.
- Group Buys
- Pavel Dudek's super Gainclone group buy
