At least I need to use NPN power amp (D44H11) and PNP power amp (D45H11)
The toshibas should be even better.... but I do not recall their "names" someone ?
I use 2SA1930 for PNP and 2SC5171 for NPN, (as Salas did). They come in an isolated case, and make your life easier on the heatsink assembly
Would love to hear that yamaha after all this years.
You would be most welcome should you find yourself visiting the UK (drop me a PM).
Those are 2SA1930 and 2SC5171 go get them!
I see it, I'm to late
These are the most important/relevant messages regarding PSU and Pre-Reg.
- Mpp #4375 PSU-pre-regulator.
- Mpp #4610 V2 Schemas UPS and Amp.
- Mpp #6506 CCS fine-tuning.
- Mpp #6462 PSU with my notes.
- Mpp #6809 Do not try to feed the CVS of the CCS of the shunt with a regulated power supply.
- Mpp #7127 More about transformer selection.
- Mpp #7635 Single and dual transformer wiring (also corrected drawing) (See also #7733).
- Mpp #7733 Grounding (PSU, RIAA and Player).
- Mpp #7810 35V PSU for the CroMagnon.
- Mpp #7830 The PSU explained.
- Mpp #8386 My resistor recommendation’s.
- My Paradise #56 PSU Noise.
- Masterpiece #951 That's not a PSRR test (it's a CIR test)
- PradiseBuilders #13 Schema's and assembly guide.
- PradiseBuilders #155 Vdc input voltage minimum simulated.
- PradiseBuilders #970 PSU oscillates; posible solutions?
- PradiseBuilders #983 Compensating the PSU for oscillations.
- PradiseBuilders #1173 Fixing oscillations (up to #1182).
- PradiseBuilders #1322 Fuse .
- PradiseBuilders #1387 Updated Paradise R3 assembly guide (Also German).
- PradiseBuilders #1403 Capacitors bad vs good.
- PradiseBuilders #1593 PSU Power Transistor selection.
- PradiseBuilders #1644 PSU Output Impedance.
- PradiseBuilders #1680 PSU Power Supply Suppression Ratio(PSSR).
- PradiseBuilders #1772 NJF selection for the PSU.
- PradiseBuilders #1887 Empirical NJF Rgs determination.
- PradiseBuilders #2127 More about the PSU fets (J113's etc).
In theory the trim pots are for an 8ohm impedance but in reality they alter the impedance as they are adjusted.
I have the details of Troels crossover and it can be implemented by retaining the standard pots if required (he uses two resistors to emulate them just as I have).
Both sq and I live in Sheffield (UK) - not far from each other.
When driving to the UK I pass through Belgium, it is easy to collect some 'Trappistes Rochefort #10' Rochefort Trappistes 10 - 100 at RateBeer When I then arrive in the UK, it then (most probably) will be the best beer in the UK
They sell that at the local pub. It's ok, but this is better.
NO NO NO! now you are wrong
Frans: Why go to belgium when you have De Molen in Bodegraven, they have alot of great beer. Although the best breweries according to me is alot of American Microbrewers (HOPS!) and Mikkeller from Denmark. There are alot of great breweries these days!
By the way De Struise Brouwers, are my favorite Belgian beer.
Anyway, enough with the beers and more paradise ;-)
Your right but it started here http://www.diyaudio.com/forums/analogue-source/218625-paradise-builders-254.html#post3554975 so I assumed that going to the UK was part of the deal.
- Analogue Source
- Paradise Builders
