Some of that seems to be to stabilize the output votage, so you can throw away the ouput cap.how complicated and oversized most OTL designs are
I meant that each valve has a minimum recommended leak value, so it doesn't go "runnaway". When you parallel valves, I would think that value should be divided by the number of valves - though I could be worng..Would 470K be enough leak to hold all those 6080's down?
RIGHT SAID FRED.
How obvious can it be?
Yes....I agree....number of valves or better numcer of triodes //'ed.
Complicated or what?
Oh no!I've seen only have maximum values for the grid resistor when used with cathode bias or fixed bias
I know I'm right here. They're max values of R, to make min values of I...
You can use 10 ohms (if you can drive it)
SPREAD THE WORD...
Assume a recommended gridleak R of 500K...now if one // the two how about the gridleak R now?
Guys wake up please,
So, why divide down the resistance value?
There's no measurable current (for IHT'S anyway) until the moment of runaway.
I suppose it depends on whether the valves runaway at the same time or not
In older days, there was also the leakage of coupling caps to contend with.
Yes. That's why we choose the highest allowed / safe value.Lowering the value lowers the stage gain of the previous tube
Disagree.Where there is voltage, there is resistance and current. Ohm's law...
Voltage is the only one that can exist in isolation.
dshortt9 said:a. Where there is voltage, there is resistance and current. Ohm's law...
So, I suppose a battery sitting on my desk has zero voltage potential - since there is no current flowing???
YEPPIE
Remember that volpot anyone?
A tube always has some input impedance. Whether it is 1 meg,10 meg, or 100 meg there is current flow.
Re: SPREAD THE WORD...
Frank, Rg is not a "gridleak"... this is the same thing we were discussing yesterday. The 6080's are cathode biased. The cathode is referenced to ground, and raised postive by the resistor in series with it. Meanwhile, we need to also reference the grid to DC ground so it will "see" the cathode as postive... we do this with a resistor. The resistor also happens to be a load for the previous tube, so we make it big, in order to not lose a lot of signal.
Is there still confusion??
fdegrove said:Assume a recommended gridleak R of 500K...now if one // the two how about the gridleak R now?
dshortt9 said:There may be many gigaohms resistance between terminals but there is current flow.
And as I said in a previous thread there also is capacitance between my amp and Jupiter... do I care???
Re: PHYSICS
What does that mean?
fdegrove said:And electrons are going to flow the way you tell'em to?
I think the reactive component (C - Miller)exceeds any perceived resistance that might occur due to spacecharge.A tube always has some input impedance. Whether it is 1 meg,10 meg, or 100 meg there is current flow.
So in the absence of a grid leak R, you're just charging and discharging a few pf's.
To reiterate:
I don't believe that any current flows through the grid leak resistor, except at startup, and in the case of current runaway.
I'd be interested to be proven wrong
