OTL, continued...
Well, after some suggestions, this is what I've got so far. How is this looking?
dhaen said:
1)You have a constant voltage load in the cathode of your driver. Where's the signal going to go?
Explain further. Do I need a resistive load above the gas tube?
2) The idea of the cathode choke was to get rid of the very lossy resistor in the cathode. You've still got one!
I need to bias the output tubes, and the point of the choke is to replace RL, not Rk... and in that capacity it's keeping another 30 watts out of the chassis.
3) Lose the attitude. :mad:
