Originally posted by Golgoth Stef, Bruno's arguments do seem to make sense. To actually hear the difference you could try testing again while deliberately creating mains disturbances eg by having somebody action a power drill somewhere in the house. Do keep us updated
I can try to connect a large drilling machine directly on the same power supply plug!
I prefer to have no problem.
OA51 said:Is there a "maximum'" limit of PSU capacitor size, i.e 100000µF/rail or whatever, where the sound quality of the UcD400 will start to degrade?
Given that you use a suitable transformer...
-like with the chip-amps...
/Stefan
chrisb03 said:
I'm also interested in the answer to this question. I have made a couple pcbs with 27200uF on each rail. I'm a bit worried that this may have a "bad" sonic difference. The capacitor banks are my last bits to go into the enclosure installation. I'm just holding off incase there is a problem with capacitor quantity.
I've also changed the layout. I have attached new pics if anyone interested.
Chris
wytco0 said:Chrisb03, I think Bruno said something about this on the UCD180 thread and someone else referred to it recently, so if you go to the end of that thread and work backwards you should find it.
I notice you have a load of what I think are called snubber caps in your power supply, why have you included them?
tiki said:Hi,
I know, it's not my competence, in my humble opinion it would be better to avoid mixing the themes between the threads. I would kindly ask you to discuss these supply problems in the appropriate thread. It will be easier to find any special information later, not only for me.
Thank you very much indeed!
For minimum capacitor requirements see Bruno's post. I for myself do not see any disadvantage for too big rail capacitors, except overkill and inrush current without a softstart circuit.
Best regards, Timo
Golgoth said:
Timo is referring to this thread:
http://www.diyaudio.com/forums/showthread.php?s=&threadid=44515
Indeed it is a good idea to summarize supply discussions in that low volume thread, as the main UcD threads have become near-impossible to browse (about 95 pages for the UcD180 thread!), and the "search this thread" function is not very powerful.
I will quote Bruno's post on capacitor sizing on that thread.
Just moving this topic to appropiate thread.
The snubber caps are base on existing designs. Link to one is already mentioned in this thread by ericpeters.
http://www.zero-distortion.com/techno/powersupply/powersi_05.htm
Chris
rha61 said:indeed there is sonic differences when you increase the PSU capacitors of a classD amp
Give it a try
start with 1000uF , and then 10000uF , and then 20000uF of same brand
it's the same effect than with chip amps ! (big damped bass and dull midrange )
alain
I don't understand why this would happen. What's the difference between using large amount of capacitance and a battery?
one of the problems is probably the capacitor impedance vs frequency curve
only some batteries give good results ( a thread talked about alkaline )
optima batteries are renowned ( high current peak , very low ESR )
www.optimabatteries.com
alain
alain
In other words, if you had low esr it's ok to have large capacitor bank?
5 channel amp-supply
Okay,
I have read this stuff. I have 5 UcD400's. If I am correct I need the following (minimum) supply (my main speakers are rated 8 Ohm):
-> 5*400/2=1000VA toroid, or should I take the 210W/8Ohm?-> 5*210/2=525VA toroid)
-> 0.5*0.1/8=6250uF, 10 times for 5 channels (or 6 10,000uF caps)
Correct?
Frans
Okay,
Correct?
Frans
Re: 5 channel amp-supply
Cap sizing is correct, but transformer should be sized as follows:
- Power factor (W/VA) for this type of supply can be as low as 0.5, in other words you need 1/0.5=2 VA/W
- Watts needed: 5*210=1050
=> VAs needed = 1050W * 2VA/W = 2100VA
Note these computations leave zero margin for impedance dips: if you want to allow for impedance dips at half the nominal i.e. 4 ohms you should double the above values, both caps and toroid (BTW there is no point in oversizing further than a factor 2 as the UcD400 will never draw more than 450W anyway, thanks to its OV and OC detections)
FransDHT said:Okay,
Correct?
Frans
the best way is to test different caps of different brands ( the result depends on your speakers )
unfortunately , big ( and good ) caps are expensive
Elna , i think , is a good standard
alain
Michel, apart from my possibly insufficient calculation (e.g. missing transformer impedance) I cannot fully agree to your statement about the higher recharging current. This current is, in my opinion, primarily dependent on the discharging one. The discharging current takes a tangible amount of charge from the caps while the approx. 10ms discharging time, independent of the cap value. So the recharging current should be determined by: the recharging time, the voltage drop (which is indirectly proportional to the capacitance), the capacitors combined impedance (ESR, ESL) and the source (transformer) impedance. The frequency dependent influence of the capacitance on capacitors impedance is constant due to the more or less constant recharging voltage rise. In fact, if the source voltage follows a sine function, the recharging current will vary over recharging time, so there is a dependance of the current waveform on the capacitance, but this is not valid for the averaged recharge current.
Again, That's only my opinion.
Regards,
Timo
Regards,
Timo
tiki said:Hi,
Regards,
Timo
Hi Tiki
when i was speaking about impedance vs frequency curve , it was that large can capacitors have often a better curve than small one
alain
alain
I have four 6800uF caps in parrallel per rail, therefore esr should be lower. As I'm new at this, I'm trying to make sense of statments made in many posts. To recap, large capacitance is ok as long as you have low esr.
Chris
tiki said:Hi,
...current waveform on the capacitance, but this is not valid for the averaged recharge current.
Regards,
Timo
Sure, I did say the "peak recharging current". Average doesn't increase of course.
Chris
what i mean is that for the same value say 6800uF , large can capacitor is often better than smaller one
in your case , i would try 1x6800uF at first , and then 4x6800uF to define the impact on the sound
For example , if your speakers have already very damped bass , 4x6800uF will degrade the presentation
I think there is no rule for power supply caps , except a minimal and maximal value , but for normal listening levels at home , reasonable values often give better results
alain
Found Bruno's post in Ucd180 thread, post 294
"Yes you can overdo on caps, at least when the power supply is hard-rectified (normal supply without chokes). The current through the rectifiers becomes more and more spiky and the magnetic fields coming off the hookup wires and even mains cords can potentially start degrading the performance of the rest of the kit. Even if you can't hear the buzz directly, you do hear increased "veiling" of the sound stage. This is one of the reasons "audiophile" mains cables sometimes have an audible effect. I don't like it when mains cables start to make a difference.
The 20000uF per rail that I have on my "esoteric amps" is really as far as I dare take it. I'm planning on a PFC supply to address this."
chrisb03 said:Found Bruno's post in Ucd180 thread, post 294
Good digging Chris, it confirms what I suspected: increased peak cap recharging current (i.e. rectifier current), which follows from increased rail capacitance, can be harmful. So until Bruno comes up with his PFC supply (PFC = Power Factor Correction) we should not exceed 20000µF per rail.
So the definitive supply capacitor sizing rule for a two-rail class D amp is:
(Number_of_channels * 50000µF / R) < Caps_per_rail < 20000µF
where R is the speaker impedance in ohms
This would mean you can't size Class D for a 1 ohm Apogee scintilla. And this is exactly the speaker where the owners are the most happy with class-d amplifiers.
Oops the forum doesn't like "mu" symbols obviously, I meant:
The definitive supply capacitor sizing rule for a two-rail class D amp is:
(Number_of_channels * 50000uF / R) < Caps_per_rail < 20000uF
Which means, BTW, that a single power supply of this kind should not power more than 20000/50000*R = 0.4*R channels! That's a maximum of 0.4*8 = 3.2 channels -> 3 channels per supply for 8 ohm speakers, and 0.4*4 = 1.6 channels -> 1 channel per supply for 4 ohm speakers
(very strange, my "mu" symbols display correctly now )
Hi Eric,
No, it just means they would be even happier if they had a PFC supply, or if they shielded their modules from the spiky rectifier current disturbances (faraday cage around each module).
Hi Eric,
Note that, as Bruno hinted at in his post quoted by Chris, the rectifier current spikes could be smoothed out by inserting suitable chokes upstream of the capacitors. This would double up as a nice mains filter BTW.
Correct me someone if I am wrong, I find that a 2mH choke inserted between the rectifier and the hot end of the 50000uF rail capacitor would yield a low pas filter with a cutoff frequency 1/(2*pi*SQRT(L*C) of 16Hz, i.e. well below the 100 or 120Hz full wave rectifier current frequency.
Mmmm... it does look like a nice and simple way to achieve both passive PFC and mains filtering with oversized storage capacitors, but we would have to make sure that we don't run into nasty overvoltages when consumption changes suddenly, eg when a silence follows a loud thump. In other words we would need to make sure there is enough damping resistance in the RLC circuit: this may be a case where excessively low capacitor ESR could harm
- Class D
- Optimal supply design for UCD and Zappulse modules
