OPA541AP Subwoofer amp
Hi!
Can someone help me to build a subwoofer amp with the OPA541 chip. If it is supposed to be 4ohm stable, do I need to do a parallell setup, or maybe a bridged parallell?
How many watts will it then push out?
Anyone got schematics for these setups with the OPA541?
OPA541 or OPA549 for a sub amp? (or another IC is better?)
Thanks for any answers! :)
build something like this.
you can use the opa541am/ap, just put a link from after Rout on each chip back to pin 1/8 on the opa541am/ap. it will give you 200W in 4 ohms ;)
http://www.national.com/an/AN/AN-1192.pdf
edit: you can also use lm3875/3886/opa549 ;)
Thank you for the answer :)
Is it really this simple? No other parts, except those in the power supply?
How can I figure out what trafo to use when it's used on a 4 ohm subwoofer? What secondary voltages, and what VA rating is needed?
I plan on buying ToroidTM trafo, I see you use them Mad_K, are they any good?
I see from the datasheets that the OPA541 delievers 5A continous and can handle +-40V on the supply. The OPA549 can deliever 8A, but it can only handle +-30V on the supply. From http://focus.ti.com/lit/an/sboa082/sboa082.pdf you can also see that OPA549 has lower THD+N.
How can i calculate how many watt they will deliever at 2ohm, 4ohm or 8ohm? V^2/R=W, but how do I find out how many volt it can deliever. It can't deliever as much as the supply, or am I wrong?
Is current calculated V/R=A ?
I want to find RMS values. Is it then (V/root2)/R=W ?
from opa541 datasheet "Voltage swing=Vs-5,5 @Iout=5A"
The wattage @4/2 are normally limited by current P=((I*root2)^2)*R. R=8/4/2..
Ipeak=V/R. Irms=Ipeak*root2. for Prms use Vrms and Irms.
To know your psu voltage under load this little tool is helpful: http://www.duncanamps.com/psud2/psud2_setup.exe
