Augerpro has started posting horn measurements. Of the ones he has posted so far, the 10"x14" QSC looks pretty nice and it's under $10.
http://sites.google.com/site/drivervault/driver-measurements
Brett said:
Has anyone bought any of these lately?
I'm interested in 4, but John at AE speakers bought some a while ago and posted pics that were really off putting, especially as I'd have to import them.
Any feedback guys to make me feel more confident?
Assistance Audio says the bolt on DDS are still crap and they only are getting the screw on versions right now but they have none in stock.
Defo said:At which frequenzy does the TD12M beam 60 degrees?
Defo said:Does the small Stereo-Lab 1000hz tractrix beam less than the larger ones at higher frequenzies? Considering the larger ones are way longer in depth..
Bumping these
tinitus said:If you are very concerned about beaming I dont think you should cross any woofer much above 500hz
I though horn/waveguide beaming was controlled by the dispersion angles of the design
The concept is to match woofer and waveguide directivity at the crossover frequency....
sannax said:Defo: which driver do you have for 1200hz and up..I guess some compressiondriver?
The plan is to use the AE TD12M which has exordinary good extension up 4khz on axis. I guess due to the low induction and phase plug.
That was the idea yeah If dispersion of the 1000hz Stereo-Lab horn is 60 degrees, and good extension down to about 1800hz as stated earlier in this thread, then I need to know the 60 degree beaming frequenzy of the TD12M.
The crossover is active with 4th order LR slopes.
jzagaja said:Why we have to buy compression drivers in Europe for 150-400 Euro when made to the same spec in China for almost ten times less? And we have to worry about the fitting.
Where do you buy these chinese versions?
I'm trying to find reliable source. But for example Wharfedale D532 1" Titanium cost only 20$ (American Music & Sound).
Is there a formula.....
to determine woofer directivity at a given crossover frequency. I understand how to calculate when a woofer starts to beam, but can we calculate when a woofer is at 60* directivity vs. 90* directivity?
Or is this a measurement issue, requiring horizontal polars?
Thanks for any help you can provide.
Re: Is there a formula.....
The chart in Dickason Fig. 0.14 suggests a 15" is 60° @ ~2 kHz.
There's a formula, Keele, I believe.
OR, you push a button, apparently. Here's a 12" JBL midbass driver:
OR, you push a button in LEAP Enclosure Shop, apparently. Here's a 12" JBL midbass driver:
Or look at some actual measurements.
TD12M at 0, 20 and 40 degrees.
catapult said:Or look at some actual measurements.
I cant really interpret the 60 degree beaming frequenzy from this... Any help?
- One inch waveguide/horn - which one?
