Ah...I see the fresh stock of diodes has arrived.
Hi Jorge,
I honestly wouldn't know how big that offset would be if you connect an 8 R load.
Any suggestion on your part to null it...if possible at all?
Wouldn't an OPT take care of it?
I mean, he must have a xformer somewhere in there, mustn't he?
Right, Steve?
Ciao,
Safety first, boys.
Hi Jorge,
The greatest problem ...is the offset....IMHO
Right, Steve?
Ciao,
Close your eyes for a minute, Frank.
The answer is a s-e-r-v-o.
frank, wrong forum. A cap would do. And some volts offset would be advantageos in this case.Wouldn't an OPT take care of it?
right, Just got 50 1N5346....from:
http://www.diyaudio.com/forums/showthread.php?postid=214212#post214212
Yes a servo as SY say ...or to use feedback at DC...if you don't want change the design of the amp...
But there are others bad things in the design...the input and the pot is referenced to the negatif rail...and the output to the center point of the power supply....there will be some ripple betwen this two points...
It needs a lot of work....
I didn't see that...Ouch.
Hi Till,
That would have to be a big motha ********r for an 8 R load, won't it?
And all fingers are now pointing at SE for suggesting triodes and not unerstanding pentodes...
Hi Till,
frank, wrong forum.
Nelson says 10000uF in the Zen. And he says 4700 are ok also.
You guys don´t think i would connect MY speakers to YOUR design without one like That?
fdegrove said:That would have to be a big motha ********r for an 8 R load, won't it?
I'm using a 4,700 uF Black Gate N on my Sziklai follower. Works fine.
And all fingers are now pointing at SE for suggesting triodes and not unerstanding pentodes... [/B]
Hehehe. I was just in a bit of a quandry about all those extra grids with regard to considering it a single active device. I'd prefer to stick with just three elements, whether they be base/emitter/collector, gate/source/drain or grid/cathode/plate. Much more elegant.
se
Very good point...
Well, yet another xformer then?
There's a chance for that too. Maybe a pair of equalising Rs can help.
Very good point...
Not sure if that can work with the complimentary FETS, I am more of tube dude, ya see...
But as far as the CT powerxformer goes, if we'd use a 0-24 VAC one and create a virtual midpoint with 2 resistors, wouldn't that cancel any ripple at the output?
Just thinking outloud here.
I still feel Single Ended Steve diserves a nice OPT, wouldn't you say?
Best solution is to use a single rail power supply...
A 10.000 uF capacitor will have a impedance at 50 Hz of 0,3 Ohms...a very reasonnable value...
fdegrove said:I still feel Single Ended Steve diserves a nice OPT, wouldn't you say?
Naaah. OPTs don't do a thing for me. It's input transformers that send me off to the bathroom with a bottle of Jergins.
IN A MINUTE, MA!
se
fdegrove said:Picture this one:
"Steeeeve!!!!"...."Yeah, ma?"
"Don't forget to take your diodes, son".
"IN A MINUTE, MA!".
Ten minutes later...Steve leaves the bathroom...
"Oh dear..., you're totally transformed, Steve".
Hahahaha! Love the picture!
se
Variac said:Boy, Now we're havin' fun!!!!!
Too much fun. I'm all out of Jergins!
se
The Schematic that Steve has posted is a good starting point but needs additional engineering work. I've seen this design somewhere before, maybe something from l'Audiophile? Also looks very similar to the ZEN V5...
If someone's interested in I'll make a design, wich will prbaby work and - of course - with the suppessor diodes at the input
bocka said:The Schematic that Steve has posted is a good starting point but needs additional engineering work. I've seen this design somewhere before, maybe something from l'Audiophile? Also looks very similar to the ZEN V5...
Zen V5? You mean Zen Variations Part 5? That's a complimentary push-pull design.
Closest thing I've seen is a little amp that Gordon Rankin did. Though it used a step-up input transformer driving a power triode in common cathode mode so you were getting voltage gain from both the transformer and the active device.
Haven't seen anything using a step-up input transformer driving a follower. Not for a power amp anyway. Though I'm sure someone somewhere has done it before. It's too much of a no-brainer.
We keep going like this and we'll have cornered the market on clamping diodes.
se
I meant this posting:
All diodes amp
Yes, you're right, the ZEN V5 is a push pull amp. But with one additional cap to the gate of the BUZ905...
All diodes amp
- One (1!!) transistor clapping...
