Hi all!
I plan to make PCB for i / v DAC use:
1. PCB use E182CC tube and output transformer.
In this link circuit:
http://www.audiodesignguide.com/DacEnd/index.html
2. Using A844 PCB Opam
What you are interested please subscribe to the list:
1..
1..
If I can use 6H30DR's and Sowter 9762's I'm in.
JD
JD
Hi all!
DAC End - the AD1865N-K with single ended vacuum output stage
1..
The only place I can find the CCF50 Dale resistor is from mouser but minimum order is 5000. Is there anywhere else or other alternatives?
You can buy som thing in this shop:
Holco Resistors
JD
6h30 DR , i love it!
You can use Sowter 9762, R gird, You can use or no, see that!
Sowter Transformer 9762 DAC INTERFACE FOR AD1865N-J
Sowter Transformer 9762 DAC INTERFACE* FOR AD1865N-J
what is the vantage to put a transformer between DAC and I/V?
With my little knowledge I think it would be better put a transformer after the tube to illiminate the C2, how Andrea have made in his DAC-End.
Klaus
Hello guys.
What is the equivallent for 1N4142?
Thank you!
you can all you Zenner diode 6-12V, It is protect IRF 9610, 840
Klaus
yes! transformer out put is the best for DAC-End!
Hi all!
1..flocchini transformer
Hi Quang Hao,
with the new PCB for SSHV for I/V Pre you have changed the circuit, you are using now the same of the the D3a phono pre.
I´m also interested in the E182CC version with output transformer, why you don´t make a two PCB version, SSHV and I/V seperated.
I just have 2 of the D3a SSHV PCB.
You have chematics for the new I/V-SSHV for DAC?
Klaus
Klaus
Hey guys, about to order 1uf caps. I'm going to order 2 x 1uf Mundorf Mcap Supreme for the I/V. Was just wondering if I need premium caps for the Salas Shunt as well.
Also, in the BOM, it says 2A/800V Diode 1N5819. Is it suppose to be 1N5062's instead cause the 1N5819 is 1A/40V.
- More Vendors...
- Quanghao Audio Design
- OLD THREAD DAC End by Andrea Ciuffoli
