MURATA POWER SOLUTIONS|DA101C|TRANSFORMER, DADT, 1.00-1.59MH | Farnell Australia
how about that for the tranformer, i see a few other dacs have used this.
Terrific, thanks Adamus. I will by the DA101C. There are also 102 and 103 and have differences but I'll buy the 101C as you said.
Does it cost only $ 5,25? very cheap... How many transformer for your DAC? Is it 3? all of them using this DA101C?
Does Andrea recommended it too?
this is the spdif tranformer, not the power, so only one.
I measured the voltage high voltage!
Can somebody tell me, what does this number mean?
Has anybody found suitable tranfromers? If so, please reveal the source! Thanks!
Me too....
Transformer for Power Supply I/V Stage (Anode + Heater)
Part Number:
R80-36 primary (0-110) x 2 /SCN: scondary (260-230-0-230-260)(200mA), 2.5-0-2.5(3A), 3.15-0-3.15) X 2(3A)
For the heater series 2.5+2.5+3.15 (make sure 2.5 and 3.15 are in phase or you will have 1.85V).
Here is the link:
DIYCLUB
Transformer for Salas Shunt board (you need 2 10VA transformers):
Any 220-240 / 9+9V 10VA transformer (toroidal if possible). You can find it at any electronic parts shop.
I recommend use one 9+9 for Analog +5 and -5 rail and another identical 10VA transformer for +5 Digital
For digital input transformer Murata DA101C available from Farnell $5
Go to page 56 and see my quote. I hope it helps.
Hi Quang Hao,
did you find any mistakes in the Printing on the PCB?
Are there wrong values or can i just orientate at the
Parts printed on?
Greetings Ulf
no! it is not wrong! if you se it, you can show me please!
thank
I'm using the jj, only £10.
I'll be using obbligatos in the critical film positions. I may also look at tube rectification, a bit of air wiring will be needed. I'll try the solid state at first of course.
Adam,
Please give me your opinion regarding all these polyester caps in parallel with Oscon and near the AD1865 and CS8141. I would prefer MKP instead MKS. I've got some axial polystyrene 33nF to mount vertically. I bought some Vishay BC MKS but I don't feel confident to solder them. I excluded any Wima.
Also those cheap ceramic capacitor seam to work very well in some positions.
What do you recommend?
hi Patrick! I alway say that: about 3-4 weeds you will get it! some PCb arrive early!
It is that you! see in the image. Im sorry I post here!
Quanghao... Can you show mine? I'm afraid i give you wrong address
Can you scan it like Patrick for me?
Im in Indonesia....
Quanghao,
Both pcbs of EUVL and mind are received.
Thanks a lot for organise the GB.
Mark
Thank you!
quanghao, my boards arrived today in good condition. They look great. Many thanks again for arranging to have them made & sending to group buy participants.
Re power transformers, in a previous post andrea suggested the following: LS70-1 (2x15V, 1x12V) & R80-55 (1x250V, 2x9V).
apelizzo, does the Murata DA101C replace, or is it an alternative for the Newava S22083?
- More Vendors...
- Quanghao Audio Design
- OLD THREAD DAC End by Andrea Ciuffoli
