Official M2 schematic
Next attempt.
Dual common cathode TO220 or TO247 diode.
Fischer Elektronik SK492 heatsink with THFU clamp.
Shunt realized with mounting ept 911-32006 power terminals.
Faston or wired cable connection.
JP
Do you know whether the heatsink has a coating which is electrically non-conducting?
If not, just need to add mica/grease or keratherm to each diode.
Bleeder resistors added.
Silkscreen top and bottom added.
ERC/DRC done.
(20€/20 piece batch, green, silkscreen, 2mm 35µm FR4).
JP
I´ll order 2 to 4 prototype before proposing GB.
JP
Hello JP64
Aluminium non soldering connection are week nodes for audio psu.
Copper wire solder directly to the board are rock solid connection ,
not made by mechanical contact's only.
SMD caps and resistors are fragile. They get old more quickly.
Throug hole component's are the best choice in my opinion but that only me :D
Anyway you get talent for design stuff so please make more :up:
Congratulations :)
Salut @Soundhappy
the vias are using in large quantity to connect ground planes on top and bottom side; using via filling would give you bare copper and this is in my opinion very important for audio power supplies. I´m using successfully this technology since 20 years for digital or analog power supplies
Do you´ve serious studies about THT vs SMD aging behavior? I´m using SMD technologie in telecom and military projects ( >10 years LC) since availability and without noticeable fealure rate.
You should apply complete coating to the board.
Notice, that the loaded components are right dimensionned and THT.
Since the connector is pressed in (gas-tight, best ever connection), you don´t need large eyed pads! This connector is one possibility: take a big soldering iron to connect both power planes (plated area) and big gauged cable (bad connection in my eyes).
DIY´er like to solder cable directly on pad of PCB, cheaper but quick dirty solution, only my opinion?
Merci pour les critiques, bonne fin de semaine.
JP
As mentionned, I´m waiting for PCB boards and will order PSU prototypes after quality evaluation of my new PCB manufaturer.
Boards will be equipped and tested, all reported in a test report, considering as FAI then complete documentation available.
After this, perhaps after some corrections, I´ll propose GB.
Nobody wants to buy "die Katze im Sack".
JP
Salut @Soundhappy
JP
Hello JP
My point of vue is from my own diy audio not professional "expertise".
For example i get analog musical synthesizer's instrument's some vintage Roland and Korg with THT
and the modern SMD ones like Elektron or Dave Smith Instruments.
Old one work after 40 years and modern one's need reparations after 3 and 5 years. Sound very nice !
Well i am far from genaralise but that my personal experience with machines who use SMD compononents.
Probably not high military quality product's.
Me like large pads and big components i understand people who want try other construction options.
Have fun and nice week-end.
Thank You and best regards :)
PCB only.
First modifications:
- bleeder resistor SMD or THT
- LED resistor SMD or THT
- bigger eyed wire solder pads
Replacing SMD capacitors with THT ones will need larger PCB (principaly for the rectifier diode snubber: SMD one was very nice to place)!
Is there a recommendation for film capacitors in parallel to electrolytic ones?
JP
PCB only.
JP
Hi JP
That nice Diyers friendly boards.
Free components choice and wire, connectors type is cool options.
Film capacitors can be Vima brand polypropylene for example.
Very appreciated :)
PCB only.
JP
Kudos on your very nice PS layout! Might be good to have a bit more space between the stinking hot thermistor R165 and adjacent PE connector?
BK
