My MJK OB's
So I hacked together a couple of test MJK OB's. I used the FX-120 instead of the FE-103, otherwise as spec'ed by MJK). I just determined an initial amount of padding tonight to try by measurement. I have only listened to them a little and in very non-ideal circumstances as I am away from home for the summer (No tubes, laptop source, inadequate room). They appear to have lots of promise.
I have no pictures (they are just two boards and some crossover parts strewn on the floor) but I do have some measurements, taken with fuzzmeasure and a modified Rat-Shack meter (replaced electret with panasonic etc. - unsure of response above 10K) in a tiny room.
First is the FR with and without padding
Scottmoose said:Madisound for the Fostex, Partsexpress for the Eminence.
You can get the Eminence from Madisound, you have to ask, and you might have to wait while they get it in.
dave
kristleifur said:Hi gang,
do you know where you can order the Eminence woofer along with Fostexes, either FE103 or FE108E Sigma? Both at the same store, I mean.
Preferably in Europe, but US is OK. Thanks!
Try Hifi Kit in Stockholm, Sweden. They sell both Eminence and Fostex. I have not seen Alpha on their web page but send them a mail. They are usually helpful.
http://www.hifikit.se/index.php?id=1154
Peter
rjbond3rd said:
Hi Wixy, yowza! The 97db FE208E-Sigma in the MJK OB seems like it goes against the spirit of the design.
One of MJK's key insights is to choose a fullranger that is a good efficiency match for the woofers and overall design. (This is why he chose the FE103E at 89db efficiency.) His earlier OB's 98db Lowthers were almost "too efficient" making it harder for the woofers to keep up, necessitating 2 woofers per side, active crossover etc. (though he could have opted to pad down the Lowthers but that seems wasteful).
Won't you need a tweeter with the FE208E-Sigma? So now this seems like you're taking another hit here -- padding down a super-efficient driver, but then still having to add a tweeter.
I can't recommend an LPad except to say you probably should get one rated at high watts, because you'll be pushing more watts through them (because you're throwing away 8db of efficiency, hence more watts will be needed -- disclaimer: I'm new at this and might be completely wrong.)
Oops, I meant to type FE108EZ, not FE208EZ. So sorry that you typed all that but thanks all the same!
MJK said:I have updated the three driver worksheet to reflect a Fostex FE-167E driver with two Alpha 15A woofers on a similar size baffle. It is kind of the bigger brother model of the FE-103E design. A little deeper bass and higher efficiency with similar crossover requirements. You can look at the designs by opening the pdf's of each worksheet on my MathCad Models page.
Has anyone built this one yet?
BR
I thinking of trying out dual Alpha's with the FE167E for my fisrt OB.
What kind of effiency could I expect on the 20" baffle with two of the Alpha's?
What kind of effiency could I expect on the 20" baffle with two of the Alpha's in a u frame with a 7.5" cavity and 16" x 16" cross-sectional area?
Just wondering if I could get away with the 167 with a u frame.
BR
BR
Wow, they look very nice!
Do the stands support the speaker well enough so that it will not tip over?
Does anyone know if the the stands placed either side of the back of the woofer like that would have any effect on sound?
I'm also wondering, does elevating the speakers on spikes decrease the bass response?
Reason for asking is i'm still in the process of building mine and yours may have given me some inspiration.
Hi BR,
Very neat construction; but what are the spikes supposed to do ?
Do you hear better reproduction when the spikes (gap between baffle and floor) are fitted ?
If a real advantage then why spikes instead of small blocks of felt footed wood ?
Can I suggest you jam some carpet in the gap and then suddenly pull it away whilst you are listening to some music having deep LF content ?
I suggest you will hear a loss of ambience, firmness and depth to the LF.
Cheers ....... Graham.
Re: Another satisfied customer
You are very welcome. Those speakers look great! Nice construction (the color matches the cat) and integration of the crossovers onto the baffle. If you send me a copy of the pictures, I would be honored to include them in my gallery.
ecir38 said:Thanks Martin for your OB reserch.
Re: Re: Another satisfied customer
Hey wixy, the depth of the legs are about a inch deeper than the rear of the Eminence. I have the baffle tilted a degree or two back which help stable them, if they were 90 degrees and you have a dog or little ones it may be a problem. Would probably do something differant next time. As shallow as the legs are I don't think they are effecting anything.
Get em done, they exceded what I was expecting .
Hey Graham, the reason for the spikes is they are being used on a carpet floor. First impressions tell me they are not lacking in the LF department. This is the kind of bottom end I was looking for, it's not real tight bass but they are very natural down low.
That would be cool. The camera I have isn't that great but I will try and take some better pics and email them to you. Thanks again.
BR
wixy said:Wow, they look very nice!
Graham Maynard said:Hi BR,
BR
Hi BR - Great Job!! Very nice attention to detail such as the installation of the x'overs and twisting of wire leads etc. Is the finish on the baffle a heavy use of paint - and what did you use for the baffle material - MDF or plywood? I also noticed that the Alpha woofer looks as if it may be mounted to a separate support and then butted up against the front baffle - I would suspect for mechanical isolation purposes? Details please!
I would expect a more effective coupling to the floor by having used the spikes and therefore a better base response - I like the idea but had never thought about it for use in OB. Perhaps you are listening to a little of that jazz that New Orleans is so famous for!
Thanks you sir, the paint is from home depot, it's two coats Behr pure black enamal. First coat for a primmer and filling then sanded, then second coat is applied. It's not perfect but good enough.
The baffle is just regular 18mm birch plywood. The original intent was to just build a test baffle but I wanted the 15 recessed which needed 3/8 deep cut out for this driver. I then realize this wasn't beefy enough and got creative with another piece of 18mm scrap behind the baffle. This worked out good for the legs since it allowed more surface to glue to. The legs were cut from a 20" round dropout from a past project cut into four.
These things sound great for all that jazz and more. One thing I have noticed is that bad recordings don't sound that bad on a nice OB which is one of the reasons why everyone should own one . Thanks
BR
BR
Thanks for the info BR!
IF you would want to take things up a notch you might want to check out BudP's EnABL treatment to smooth things out a bit.
http://www.diyaudio.com/forums/showthread.php?s=&threadid=100399&highlight=
I'm thinking of one of these along with the Fostex FE107 and the Alpha. Did you wind your coils or did you purchase them somewhere? What type of XO are you using in terms of slope and component values?
- Full Range
- New MJK Baffle Article
