how do these fare in the CGR/fOnkendesigns
They should do fine… i haven’t designed them yet. Note that the optimum A7ms box is larger than for the A11ms.
dave
1st release of the Brodgar double mouth rear horn done.
http://wodendesign.com/planset/Brodgar-title.pdf
dave
dave
dave
These do look pretty awesome. Paid planset?
Yes. Will be part of the Megalith series.
dave
Cool. Anxiously awaiting the CGR tho
Approximately the size of Victor for FE166/FF165WK, then? The two variants of this family that I’ve heard - Valiant/ Maeshowe and Victor need, I think a little breathing room to excel, and definitely 10-12 listening distance. That is of course never a problem casa Dlugos .
Not at all an unmanageable size, just not sure I can do the 9' min distance from but certainly am intrigued by the possibility. I love Doctor Scott L's BLH's, 2x Path Manifold Horn ... that's a new one for me
Guessing this 2xPMH will get the most out of A11MS's average efficiency with near zero box loss, probably gain a bit of efficiency across the BW?? Good utilization of A11MS for those of us with single digit SET fetishes???
...with WAF rapidly fading in the rear view mirror
Oh I don't know. Footprint is no larger than any other floorstander. Let SWMBO pick the color and whisper in her ear that it's too high to collect clutter, but *might* look nice with a hanging plant on top.
I likes the way you think, Dave.6 dB more sensitivity… at least with no filters. Twin FHXL.
dave
Ah, the shadow tells me. Still not sure how it's implemented though. If you stack two fhxl's you'd have to lean the bottom one forward to get the front perpendicular to the floor which would angle the top (of the bottom fhxl) so that you'd need a wedge between the two to get the top one also perpendicular. It seems the driver spacing would be wider than the image seems to show in that case. Maybe you just put in one parallel divider and not worry about it?
No photo in #355. It is a pdf inside image tags. Shows fine for me.
dave
Not showing for me on diyAudio also... however if you copy paste the link in a new browser window, the link works and the PDF file shows.
- Full Range
- New Markaudio Drivers
