New Linear Audio publication!
AX tech editor
Joined 2002
Yes it is Drupal based. I didn't do this myself, I'm not THAT smart!
A have an audio friend who has a webdesign company, he gave me a very reasonable price ;)
But you know how it is with IT projects: you take your best estimate and you double it. Then at the end it gets to double THAT.
But I had a strong hand in how it appears and should work and how things should hang together - I've done that in the Airforce for weapon system automation projects. So the designer had a good sparring partner :).
Jan
Jan
So I visited the site to purchase Pt.2 of the Equal Opportunty articles and, after submitting payment via PayPal, couldn't download the pdf. This may be because I use a smartphone. However, I also checked my associated email inbox (the one I provided to LA, not the one associated with PayPal) and was not sent anything. Figuring this error was my own fault for not having an LA account before purchasing, I registered an account but have yet to receive a confirmation email. I apologize if this is all done manually on your end and I'm just being impatient.
Anyway, I loved issue 7 and look forward to purchasing the back issues.
AX tech editor
Joined 2002
Benjamin, yes there are some hiccups on the new website - most people just sail through but some see what you saw.
We are working to find the cause and to fix it - probably has to do with ordering without first registering.
I will email you your article in a minute.
Jan
AX tech editor
Joined 2002
Some of these issues come indeed from existing registered users that try to re-register and/or order anonymously.
We are working right now to fix it.
If you know your email and/or user name try to log in and use 'forgot password'.
if that doesn't work send me an email and i will fix it manually.
Edit: Lasse what is your registration email?
Jan
AX tech editor
Joined 2002
After a lot of other priorities I'm almost finished with Ian's CubeLaw amp.
Any other builders?
Jan
AX tech editor
Joined 2002
Stupid question and wrong thread, but is there any particular need for the 74HCU04 ?
(or can it be swapped out for a smaller version, me still have bunch of Toshiba 7WU04. Seeing is Building)
I don't know about that Jacco. The '74CU is an UNbuffered version meaning each section is just a pair of an N- and P-JFET. That's why he used them - conveniently packaged reasonably matched pairs.
Changes are that the 7WU04 will do as well, but not sure,
I will see if i can find out.
Edit: found the DS. These are 3 pairs versus 6 pairs for the '74's. But they are all in // anyway so that seems not a problem. But the max supply voltage may be.
I'll check with Ian.
jan
