I would assume that they are good. I only got them a week ago and only applied power to them for the tests that you have asked for. Perhaps they are the wrong spec IRFZ44s? Here is a link to the data sheet for them. http://www.parts-express.com/pdf/irfz44npbf.pdf
OK...I tested both according to your web page "Basic Transistor Testing" and found that one was bad and the other was fine. I will order 2 more just so I have a spare. I started to order 3 at first so that I would have a spare and now wish that I had. Oh well. I should have the new ones here in about a week.
Once again....Thanks for the help.
Finally got to replace the IRFZ44s. Did a quick power up and the power supply still reads zero volts when the amp is attached. Also, I noticed that the FETs got hot only after a few seconds of power being applied. (this would be because I forgot to mount them on the heat sink) Measuring the pins on the FETs after power up I get
On the one closest to the corner....
Pin 1-2) - 0.0 ohm though, the reading climbs as I hold the probes to the pins
Pin 1-3) - 188.5 ohm
Pin 2-3) - 0.0 ohm though, the reading climbs as I hold the probes to the pins
And on the other one next to the one in the corner....
- General Interest
- Car Audio
- Need help w/ old school HiFonics Pluto
