Hi gaborbela,
Okay. The tray has a bunch of nylon rollers held in by a clear plastic strip with rectangular holes. The tray assembly is an incredible pain to take apart. I do not recommend you touch this assembly at all.
I know because one "child" got upset with his OMS-5 and kicked it with the tray open (under warranty). The damage caused with the parts prices and labour priced it into the "not worth repair" area. Now this was clearly customer abuse, but Eric Moos (Nak area rep) decided to cover the unit under warranty !!!!! He did make some idiot decisions, that was just one. So I had to do this for warranty rates. After taking it apart I was able to convince Nak to send me a new transport complete. It is a big job. Don't go there.
You can lubricate the slide and gear section. Remove the drive gear, clean all the existing grease (and hair + ??) out. Relubricate with white grease only, apply sparingly. Extra grease always causes problems. The lube in the rollers is also white grease. If you just apply more you will make a mess. I warned you.
-Chris
-Chris
Hi Chris,
You and I have corresponded before about Nak and Adcom equip. To add to this thread I have a question about a transport issue with a Nak OMS 3. Since you used to repair them perhaps you could give some insight. I've long given up hope that it can be repaired properly and w/o breaking the bank.
I've had this unit since new and it's been out of service for approx 3 years now. I used to be a salesman at the local high-end dealer that handeled Nak back in the day (mid 80's, early 90's). They are gone now and so is my friend the tech who used to work in the repair dept.
On to the issue. I can open the drawer place a disc in there close the drawer and hear a motor buzzing the standby light on the display will flash and within about 3-5 seconds the drawer open back up. I can do the same sequence even w/o the disc with the same results. Occasionally the disc will spin up and I can hear it speeding up and slowing down and the assocaited sound of the laser trying to track the info, but eventually it just opens the tray.
Any idea at all based on your experience if this is simply an adjustment issue or if the laser assembly is shot. This was repaired about 8 years ago and from my memory it had a new laser assembly fitted. I mainly would like to get it up and running for nostalgia, but I'd like to compare it to todays players. I always enjoyed the sound from this unit even though it only used a single dac instead of the duals of the 5 and 7. I've taken it apart just to look at it and it's built like a tank, very unlike today's units.
Sorry I just have the ability to repair anything of this complexity. I have done nothing with it other than open her and look.
Brock
Brock
Hi Brock,
The drawer thing sounds like a poor contact with the drawer position switches. You should measure the little switches on the transport. Might be an easy fix. (OMS-4 had dual DAC's).
The laser head will not need adjusting. It may need a new disc motor. Do not allow anyone to just adjust the unit. Some laser heads had a problem where the lens assy would stick on the post. Head replacement was the only way to fix that. Your unit may not work with the top cover off (normal). Those were NEC transports. Harmon Kardon used the same one with fewer options.
I wish we lived closer to each other.
-Chris
-Chris
Hi All,
Ive just joined this forum site and would like to ask others for more info about the Nak cd4 as I've done a search and found this thread.
After a long time with vinyl using a michell gyro SE/techno arm A/ Ortofon MC 30 Supreme.
I wanted to compare it with my slightly dusty 12 year old Nak CD4 player with identical music.
A MoFI vinyl and MoFI cd of Cat Stevens Izitso.
Well no brainer really and I wasn't expecting it to be.
But it did get me thinking that I must get round to replacing it for the music that I can't get on vinyl.
Could some tell me what the transport and DAC arrangement is in this machine? I will also need the clock frequency.
I like the look and feel of this machine so I am thinking about putting a new clock in it from Trichord Research.
Also would the transport of this machine be good enough to use as a dedicated transport?
Its probably had minimal use over the years. If all else fails I'm thinking about going retro and find a decent Teac Vrds transport or even a Pioneer stable platter, but that topic I might leave for another thread.
oms-2a info?
Hi Chris,
Wow! I'm really impressed with the helpfulness of this thread and its participants, and I've learned alot. Especially to not give up! I stopped looking for Nakamich information a couple of years ago.
I had played my OMS-2A daily until then. It started having trouble reading discs, but the lens looked clean. Besides, when discs did play, there was more skipping that eventually became a continuous clicking. If I remember correctly, the sound was at a higher pitch than skipping caused by scratches. At any rate, I decided to observe the motor's spindle as it ran, and it seemed to have a wobble. I compared this with several other cd players, and mine seemed like it was spinning on worn bearings.
I'm assuming the motor needs to be replaced. I've read in previous posts about things I wouldn't touch, but I'm wondering if I could replace the motor. Since I couldn't find any Nakamichi motors in the parts section, I was also wondering where else to look for parts.
Thanks,
Dave
Hi Chris,
Thanks,
Dave
Hello Dave,
maybe the motor of your OMS-2A is from Mabuchi:
http://www.mabuchi-motor.co.jp
Another supplier might be Copal
www.nidec-copal.co.jp
Mabuchi built the disc-motor of my OMS-5EII, the Copal was for the laser unit of the OMS-5EII.
They probably are discontinued, but maybe Mabuchi or Copal have contemporary models with the same specs like the old ones?
One problem will also be mounting the disc table of the OMS-2 on the new motor, because it has to be fixed in a certain height.
Maybe, making something like a "print" will help.
I do not know the english terms, i think at some kind of artifical clay which does not glue and can be modeled. This can be stuck between disc table and the motor body before disassembling them. When it has dried, it can be used as a reference for fitting the old table on the new motor.
Hope this helped a bit,
Salar
Salar
Hi Dave,
Check the nylon thrust bearing at the top for wear. It will have a dent.
You must sand this out, then fine sand 'til it's smooth. I use damping fluid to lubricate the ball bearing after that.
The motor is replaced by a standard Mabuchi CD motor. Cut the shaft to the exact same length and round the end. Measure the table height carefully first and make sure it ends up at the same height. Use nail polish or thread lock on the shaft before sliding the table on.
The exact Nakamichi motor came with a brass spacer. (NLA) I think new mounting holes need to be drilled also. It can be done, I did many a long time ago. My brother has the same player - still. It works fine.
-Chris
-Chris
Hi Salar,
LOL
If he is still with us (and I hope he is) he is very old. Possibly beyond caring for the older product. That would be very normal I would think.
Nakamichi's biggest problem was that they constantly swung between "lifestyle" products and some serious audio. The lack of consistency lost them customers and credibility.
Their cassette decks were the best! No question there. Now if they had ever built a full size reel to reel (the three head cassette decks treated the tape like an open reel machine), they would have been awesome indeed. Teac /Tascam would not know what to do. I think Revox and Studer were safe there. The Nakamichi electronics would have been better I think. Mechanicals and servos may have been better with Studer / Revox.
-Chris
LOL
-Chris
Hi Chris,
here you can find an excellent article about Nakamichi and Niro Nakamichi:
http://en.wikipedia.org/wiki/Nakamichi
BTW, I want to order a YEDS-18 Disc now. (I know, the most expensive way to go...)
But were there several issues/versions of this disc? It is sometimes stated as "YEDS-18, Type 3 and 4", which sounds like that. I asked Sony, guess what, they don´t know and told me to ask the distributor for Sony spare parts, I bet he will not know either...
I will also have to take care on the belts. About ten years ago, I used vaseline for greasing the mechanism, which crawled everywhere because of the heat. I cleaned this mess maybe 3 years ago with alcohol and now use a special grease for suspension forks (which does not crawl and does also not attac rupper or plastic), but still the mechanism becomes greasy after some months from the last remains of the vaseline... I will also try a heatshrink tubing and a second rubber belt around the gear driving the original belt.
BTW, What were the srevo mods you were talking about? Just curious, I will not open my Nak for this. I did it so many times during the last 16 years, that some screwholes start to show wear...
All the best,
Salar
All the best,
Salar
Hi Salar,
The major servo mod was for the OMS 5/7. Stock it will reject defective discs, after the mod it will play them unless they are really bad. The type II machines have no mods that I am aware of.
This modification is a small manual all in itself. Major work is done.
-Chris
-Chris
Questions about pickup/measuring
Hi Chris,
got a YEDS-18 - you are right, mesurement does not differ from a well manufctured CD. I also replaced the pickup - KSS-123A. (the lens of the old one looked slightly greyish/dirty, but still worked)
I did not have the machine hooked to the stereo, when I made the alignment according to the service manual of the OMS-5EII. The waveforms on the scope looked o.K.
I grounded the Nak as well as the scope when measuring.
But even though the variable resistors did only need a slight readjustment, I hear a rythmic scratching (i.e the sound of a worn out burned CD) even on the YEDS-18, after I reassembled the unit and hooked it on my stereo.
This has never been before.
Foolish me, i did not have a final look on the eye pattern before reassembling the Nak.
Could it be, that a laser comes sometimes mechanicaly misaligned from the manufacturer?
Maybe Sony as OEM made several preadjustments for their customers? (Unlikely, this KSS-123A came as an original part from Sony, not nakamichi, and it replaced a KSS-123A, which also was an original part from Sony as well.)
One question:
I realign voltage when adjusting Focus, Track, E-F balance, right? (the waveform on the scope travels up and down according the turning the variable resistors).
If, as one example, the waveform should have a symmetrical plus-minus swing, whot do i take as reference when adjusting the line on the scope horizontally before measuring on each step?
Probe to ground? Or the probe to the test pin to be measured, with no signal yet?
Had a nice talk to a tech. He stated that to his experience, many faults of old laser units did not come from weak diodes but often dirty mirrors inside the unit...
He cleaned some in an ultrasonic bath.
All the best, Salar
Hi Chris,
One question:
All the best, Salar
Hi Salar,
The eye pattern is the most important signal to look at. All the adjustments you make are to increase, sharpen and stabilize this one waveform. I view the factory alignment as a starting point.
If you were to look at the eye pattern while playing a disc, you would see that the noise corresponds to the eye pattern becoming less well defined. You are hearing uncorrectable digital errors.
Your "0 VDC" reference for your offset adjustments is the ground on the servo board. Using a DVM will give you variable results due to the noise levels. You need to balance the 'scope on that range for zero volts before attempting the adjustment.
The Sony heads are fine. I've used them for years, they used to come from Nakamichi. Be aware that some of these heads get sticky on the pole piece. I was successful in repairing one recently.
-Chris
-Chris
Hi Chris!
Thanks for your kind and quick replies!
Just came in my mind, that once during adjustment, the servos once "ticked" when I started the cd(YEDS-18, Type4 no manufactured errors), but did not, when I stopped the CD and started it again.
As far as i remember this effect appeared randomly.
I will try another adjustment in some days.
BTW, variable resistor RV105 is for the drop out detection,
not for the APC circuit? I am asking because I do not want to mess up the laser power, when I try RV105.
All the best,
Salar
All the best,
Salar
- Digital Source
- Nakamichi OMS-5
