Sory, I wasn't clear in my response. I was refering to the alternate compensation mod. We are going to have to give them their own names.
Found an old BP-150 board with surface mount spots. Here's my little down and dirty production showing the simplicity of the process.
https://www.box.com/s/696f9e6ddd503832495c
This one is a little plump, but will work just fine. Some solder wick painted with flux works great to remove any extra solder.
P.S. Look out Spielberg!!
Nice work, though, you need someone to hold the tweezers for you to prevent the resistor moving, hence, you have better control on the soldering process, in other words, the amount of solder. You cave me a push toward trying that by myself.
Thanks for the video :- )
Nice video, Bob
Only a suggestion wet (much) less the point, it will avoid that excess of solder.
A good smd solder joint should have only a tiny amount of solder.
Interesting link with lots of pics of excessive solder:
http://www.technolab.de/_en/solderdict/smdhmd/excessivesolder.php
Hey Bill, I just wanted to thank you for that link you posted, All About Circuits : Free Electric Circuits Textbooks
I'm learning a bunch from it, though I do glaze over on the vector math. For anyone new to the hobby, it's a great read. Thanks again.
Not screwy numbering.
The first two digits are the value to two sig fig.
The third digit is the multplier.
0= add nothing to the first two.
1= add one zero after the two digits, = multiply by 10,
2 = add two zeros after the two digits, = mutliply by 100,
3= three zeros,
5 = five zeros.
The J = tolerance. = 10%
3= three zeros,
5 = five zeros.
Well that's just fine - With all the long leads I can't play any music, but I can get 12 FM radio stations.
No, actually they sound very good. More clarity, some of the forwardness of the last configuration is lessened. Most noticeable is the reduction of sibilance on the vocal from the test mix.
I'll start the Isotek process and report back in about an hour.
Bob, trim that leads!
7mm will be good.
Like the song says "You don't know what you got till is't gone".
I don't know if there is something called a "Mid and High noise floor", but if there is these Amtrans caps remove it. After the Isotek I discovered, as good as the FEs were performing, there were elements that could have led to listening fatigue. That sounds like coming in through the back door, but that's the impression I'm getting.
Again, there is a whole new quality to the presentation that will take some time to appreciate. A one word description would have to be "purity". The cleanliness IMHO, does pull back the warmth (what Dario calls coloration, I believe) just a tad with my speakers, but I think it's a good trade off. I also have a pot on the midrange section of the Sunflower crossovers and can probably pull it back in with some adjustments.
The "In the room" presence is excellent. The finale to Copland's Organ Symphony is very complex with a cathedral pipe organ and an augmented orchestra. It sounds glorious. Snare drum rolls come through the blasting brass and the floor shakes on the pedal notes. The front to back stage is one of those things I'll have to investigate further - it might be a bit slimmer but not by much. The general 3D ambiance is totally room filling.
Don't know who gets the attribution, but whoever found these gems gets a double gold star. At $2.50 ea, the Amtrans are almost a no-brainer.
- Chip Amps
- My_Ref Fremen Edition - Beta build/Fine tuning
