Most who look at the schematic will see right away that this arrangement has been used with tubes for quite some time.It is very simple with no global nfb, it uses only local feedback in the first voltage gain stage then feeds a phasesplitter for the push pull output. Will build it soon and pass on the word. Under sim i get a nice 10 watts into 8 ohm with a sensitivity of 3volts so a preamp is a must for full output.
Be carefull, I am afraid your circuit wont work..
This input stage looks fine. Allthough it is not obvious, the input impedance is only 12K or about due to the feedback arangement of the two 100K resistors. Besides that the lonely 2n3904 will have to cary 13mA @15Vce = dissipate 200mW.. I only guess but won't it will get warm... wihile it's only rate at 40V, you are running it from a 50Volt supply...
Your output stage is all wrong. You cann't just make a BJT version out of a tube circuit...The output transistor won't be working together in push-pull like this ..This kind of phase splitter /bias arangement is just wrong..You got to look better at your spice programm.
Besides..you're idle current is complete depended on the output BJT current gain.. running of 50Volt at 1A they will get very hot and you'll have a hard time stabilizing the current..
But I do know a good old 4 transistor amplifier design... it's calles the John Linsely Hood 10W Class A amplifier.... scale it up to 50Volts if you need to .. you'll have a great amplifier..
goodluck!
goodluck!
Interesting Jerluwoo.....much more than i was hopping for related you
A nice idea.... very interesting, and in special a much better product than i was expecting as in your personal informations i could read only Blah, Blah and Blah.
I think you are much more than those things you are trying to make us imagine about you.
regards,
Carlos
regards,
Carlos
I couldn't agree more with you on the JLH amps as I have built a stereo pair and love them. It is true that the output isnt exactly push pull but rather more like single ended with a varying ccs load. Resistor values for the phase splitter outputs will have to be determined by measured transistor gain to equalize the current at each emitter of the output trans.
Thanks so much for kind words Destroyer I always enjoy reading your posts. As for my personal info I'm mainly just a music junky that has toyed with stereos most his life. The only background I have in electronics was a rather poor 2 year course in electronics repair at the local vocational school. I find building simple circuits and testing and toying with them great fun, who cares if those cheap ratshack transistors go to pot.
As of about 30 mins ago I started listening to this amp (yes it does work,better than i could have thought) and it makes some nice music, very compareable to my JLH's. The treble is very "crisp" so to speak and the mids are smooth no glaring and the bass sounds tight not muddy at all.
ps. I did however dig up a 30v supply to use with it as the argument against the input trans is very true and didnt want it to self destruct before I had the chance to listen. The only resistor values changed were the emitter resistor on the input trans to 220 and of course the ones at the outputs of the phase splitter both at 1k.
The only real dismay I find is the very poor ripple rejection but I am only using a very basic supply using +/- 30v center tapped trans into a large flat pack rectifier with 2 ~ in and a center + only out and a single 22000uF 63v cap. I will have to make a decent supply for it when I get more time.
After some time listening it still sounds pleasing without harsness but the hum is getting to me will have to futher evalute when a much quiter supply is made.
After making a simple choke filtered supply and getting rid of the hum, I hooked this amp to my main listening speakers. You can believe me or not but the sound is something different than what I had expected. Having always heard people say that they could hear the air between the recording mikes, I had thought it was just bs that people talked. I heard what they were talking about for the first time last night. This amplifier has something special, I had not heard a ride symbol hiss for 2 measures after it was struck. The JLH's were my reference to good sounding amps but this circuit has something more, the treble is amazing and the difference between loud and soft sounds are huge.
Getting the bias center is a bit tricky though. Refering to the schematic I posted, it is a balancing game between r6 and r2 with r4 being kept constant. When the current is increased through the output stage, current must also be increased through the voltage stage to balance the output voltage back to half supply. Also the amount of power dissapated by the phase splitter trans and input trans becomes much higher with higher output current. I changed Q1 to a tip42a and Q3 to a tip31a as the heat on these 2 were a bit much when i got the output to settle at 1.6 amps at half supply voltage.
For those that love high effiency speakers ran on small class a's this circuit may have something that you will enjoy.
For those out there much more knowledgeable than me, I would love some tips on how make a suitible bias arrangement for this circuit.
Just wanted to post up the schematic at the values I am using and listening to. tschrama I'm not sure exactly what you mean but if you are saying as a way to balance the bias it will not work that way. Q2 of this schematic is the varying ccs load and supplys a larger amount of ac current than Q4, actually with some current gain over the idle current.
hello
jerluwoo
your amplifier is on the right track
but i find it will not work very good
not today - but maybe tomorrow, with some little change
I want to tell you how I learned about amplifiers and transistors
The 2 best 'schoolbooks' i had
was these two good websites below
from two amplifier designers that want to share with us.
(also you have Nelson Pass DIY site www.passdiy.com with very good articles and schematic examples)
DESIGN WITH DISCRETE TRANSISTORS.
http://www.dself.dsl.pipex.com/ampins/discrete/discrete.htm
From the Douglas Self,
AMPLIFIER INSTITUTE
http://www.dself.dsl.pipex.com/ampins/ampins.htm
and
Elliott Sound Products Audio Articles - Page Last Updated - 23 July 2006
Feature Articles
http://sound.westhost.com/articles.htm
For example:
Amplifier Basics - How Amps Work - How amplifiers do what they do
http://sound.westhost.com/amp-basics.htm
jerluwoo
AMPLIFIER INSTITUTE
and
Feature Articles
For example:
* Part 1 - Valves (Vacuum Tubes)
o Valve Characteristics
o Valve Current Amplifier
o Valve Power Amplifiers
o Summary
* Part 2 - Bipolar Transistors
o Transistor Characteristics
o Transistor Current Amplifier
o Transistor Power Amplifiers
o Summary
* Part 3 - Field Effect Transistors and MOSFETs
o FET Characteristics
+ Junction FETs
+ MOSFETs
o FET Current Amplifier
o FET Power Amplifiers
o Summary
+ Junction FETs
+ MOSFETs
* Part 4 - Operational Amplifiers (Opamps)
o Power Opamps
* Part 5 - Some Basic Linear Circuit Building Blocks
o Current Sources and Sinks
o Current Mirror
o Long Tailed Pair
o Grounded Grid (Gate or Base) Circuits
o Cascode
* Part 6 - Conclusions
* References
* Copyright & Update Info
Thanks for the links lineup some interesting reading there. As for the circuit not working very well I would have to disagree. I've been listening to it for 3 days now and it works quite well. Sound quality rivals the JLH, the JLH has a little "fatter" bottom end in the bass region but this circuit surpasses it in the treble department. Dont get me wrong it has very tight good sounding bass all the way down. This circuit also will reproduce almost perfect square waves on my oscope. The major issue is balancing the bias because of the dependency on trans beta, I spent much time measuring and changing values and remeasuring.
I now have a second circuit up and running. Using the same values of the latest schematic I posted it started up and is playing perfect with 1.7 amps idle current. I did not have a pair of outputs that were very closely matched but it doesnt seem to have an audible effect.
Maybe you should check the Iac though ech of both output transistors and the Iac though you load.....
just do it and you might actually understand what you are building...
For any of you who builld and play with this circuit dont be disappointed if it is very low volume, a preamp able to swing 3v into 10k load is a minimum to use. This circuit has intentionally a very low gain.
Although I'm not real knowledable I do understand how this circuit works. Refer to the disscussion on the Class-A website discussing the output stage for the JLH, single ended or push pull. That is where I derived this circuit, only instead of a vas driving the output mine is working in current mode. The top output trans and the phase splitter form a complimentary pair for current gain while the lower output trans is the current sink.
- My simple class a approach
