Joined 2009
I like live music, both orchestra in the big posh palace and loud rock in the pub basement. In the first case, the orchestra, I'm usually not close enough to pick out the position of instruments, but rather the whole concert hall is full of wonderful sound. Stereo simply has no place there. In the second case, it's usually so loud that that the sound comes from inside your head. Stereo has no place there either.
Dianne Krall - good choice.
Joined 2009
I can feel a conspiracy theory coming on.
that would be the price of Neo magnets !
I agree. Like the early mono setups. Very room filling (wide dispersion). Think jukebox in a bar sound.
But anywho, I'm glad you like the drivers. I'm still waffling.
I'd like a large open baffle (the phy one), but I'm not going to make the huge thing for a single 5" or an 8" driver. The flying wing is close, not quite as wide as big phy open baffle. It is a vmps rm60, 7" wide front, 6' tall, with 2 baffles 2" think mdf sweeping back, 22" wide open in the back, I think 18" deep, with a removable foam thing (like I think).
But it is a nasty 3-way, unlike our precious full range drivers we cherish here !!!!!!
pics at bottom.
CES 2007 pics
Norman
pics at bottom.
CES 2007 pics
Norman
Joined 2009
It deserves a big box, something like 250 litres by my reckoning. It's time I built a big speaker
I was thinking a bit larger , though admittedly I would shrink them to ~429 L if building from scratch: http://www.diyaudio.com/forums/full-range/194043-fonken-10-audio-nirvana-4.html#post3069174
GM
GM
You with undersized boxes Greg? Never thought I'd see the day.
What can I say? It's an early vintage style driver, so figured an early vintage mono alignment driven with a high output impedance for spinning what's left of my mono vinyl collection.
For modern systems that typically require some form of passive EQ to mimic vintage, the above system would ideally need to be 2x larger, so 'BIB' will always be the default alignment in my DIY Speaker 'Cookbook'.
GM
GM
Sounds like a plan to me.
+1. Only trouble is, I don't have the space...
Joined 2009
Are we talking about a BIB with a 15" driver here?
No. Just that up to a point, bigger is better, i.e. the larger Vb alignments usually win out.
why not ! - so how big do we need to build it ?
Give or take, 20 3/4 ft long if you're tuning to 1/2 wave Fs & a Vb in the order of 175ft^3.
Joined 2009
Joined 2009
- Full Range
- My New Audio Nirvana Drivers
