My latest project - DAC + headphone amp
Hello,
i´m Frank an im new here. I´f build a simple DAC with near the same schematic, but it make trouble.
DAC is the PCM1792, I/V-Stage the OPA4134. It works and sound, but the OPA heat up that he burns my fingers after a few seconds. Over the resistors (750 Ohm) i have a voltage from 4.4V, so the output current is 5.8mA. It´s all in green range for the OPA, why he heating? Normal?
thx for replay
Frank
Hello,
thanks for replay, i will try it with an heat sink on the OPA.
Additional informations:
In Bipolar Zero Stat the current to the OPA 4134 is 12mA on the +15V-Rail and 60mA on the -15V-Rail. Each Amp drives 12mA - thats IMHO seems to be OK, can everybody confirm this?
Hallo kct,
vielen Dank für Deine Antwort. Heute hab ich noch mal gemessen, der OPA zieht 60mA an -15V und 12mA an +15V. Jeder Kanal treibt 12mA - sieht für mich alles OK aus. Dennoch wundere ich mich etwas über die Erwärmung.
Werde es mit einem Kühlkörper probieren, mal sehen ob was abbrennt....
Gruß Frank
