Hi Joe,
There are are still a number of things I'd like to do before I present it to you or anyone else.
I want to test it on low efficiency Spendor speakers of a friend of mine and on my bigger and high efficiency SD3s.
On top of that that I'll need to inventorise parts, draw a schematic on th PC, and so on.
Eventually, when all of the above is finished and I feel confident it is satisfactory I will gladly share it with all of you.
So, if you're really in a hurry to build I think Jack Eliano's SE circuit may give you a good feel of what you can expect of a 2A3 and the 5691/6SL7. A combination that should sound very good.
Now I know that you have a PP 2A3 design in your pocket. Do you really want me to beg?
Hi Tim,
Afraid of letting down someone I think...
I'd never release a single thing unless I'm convinced it has a good chance of surviving in a fair number of systems.
BTW, since you're our resident penthode defender: I spent most of the afternoon listening to a homemade 9W PP 6V6 stereo amp on (84dB) Spendor BC Ones this afternoon with a humble old Philips 16 bitter as a source...Stunning, absolutely stunning!
The closest to my OTLs from a xformer coupled amp I've ever heard...Goose bumps all over.
High-end stuff costing several thousands of $s has a lot to learn.
And no, not a single boutique component insight either....I was really impressed...
Original design by Western Electric, no global NFB but plate to plate FB. Clever and incredibly musical.
I release drawings without the slightest thought of building anything first, what are you afraid of?
i don't mean to hijack the thread but, ..
methinks the sound of the 6v6 in hifi is under-appreciated, .. i own a couple of 6v6 push pull pentodes (williamson ckt.) pilots and absolutely love the sound. i i liked them even with with my PSB 400i at 80 something eff, .. and they are scary good with my high efficiency horns.
any reason why this tube seems to be much less spoken of than say the el84 or other relatively cheap power tubes?
Absolutely no idea. Maybe has little power compared to the more popular 6L6? But that begs the question of the EL84. Maybe it gained popularity from use in guitar amps as pairs and quads.
Glad to hear there's hope yet, Frank
I don't have a 2A3 amp, my pocket doesn't like the idea of them for some reason... but I have made a PP 12AU7 amp.
Tim
Tim
fdegrove said:BTW, since you're our resident penthode defender: I spent most of the afternoon listening to a homemade 9W PP 6V6 stereo amp on (84dB) Spendor BC Ones this afternoon with a humble old Philips 16 bitter as a source...Stunning, absolutely stunning!
I've been running one of Gary's PP47's for a while now, and have been playing with similar designs using EL34 and 6V6/6AQ5 as time from work permits.
Got to agree, they can be extraordinary, better than almost all the bright emitter transmitter tube amps I've built (my reference standard up until recently). They make great electrostatic headphone amps too.
- Tubes / Valves
- My first tube amplifier
