My first shot at an IGC
Well I have been collecting parts, and reading everything I can find on building a Gainclone. Last weekend I built the power supply. yesterday and today I built the amps. I am very satisfied. I ran into NO problems, I used the schematic from Decible Dungeon, I built EXACTLY as the plans show and the worked perfect on the first try. I plan to build a case around them later as time allows, Maybe using more acrilic as the tom or front, we'll see. What do you think about my layout? I tried to stay as symetrical as possible.
Thanks for all the info, DD especially.
Hi Everyone.
First time on this forum. Just built this.
http://server6.uploadit.org/files/alnewall-DSCF0002.JPG
It's a fairly basic interpretation of the Decibel Dungeon one.
Been running in for around 6 hours now and sounding quite impressive. Not so far removed from the valve sound that I am used to.
This is the first thing I've ever built, apart from speaker crossovers. So a big thankyou to NUUK for his superb plain english website.
This was a great way of learning the basics and gaining a bit of confidence.
Bye for now.
AL
Congratulations to you too Albo - another nice neat layout and I see, like me you use your local hardware shop! ;)
Building on a piece of wood is an excellent way to build a Gainclone before putting it into a case. My OPA buffered IGC is still on its plank after more than seven months though! :ashamed:
Seems that we are doing well in 'spreading the word'; what next? world peace? :grouphug:
Aunkst.
Did you put the 216k resistor in, between pin 7 and signal ground?
This dropped the offset on mine to less than 1mV. Although it wasn't very high to start with. This addition was mentioned after the build instructions, but not on the schematic.
Albo
Aunkst said:
I just checked the DC offset at the speaker terminals,
I got 21mV.
Is this too much?
I asked my electronics professor and he says that ANY DC is too much and he recomended putting a 100uf cap in series with the output.
what do you think?
What? #&@&%#&*@%*!... Oops, forgot that I don't swear. :angel:
It will kill the DC all-right, it will probably also kill the sound. It will most definitely kill the bass as 100uF just isn't enough. Even 1000uF will get you -6dB at around 20 Hertz.
No, 21mV is not too bad a result, I have a friend's NAD 317 amp here and it had a bit more than that, so in a commercial product this was deemed OK. Personally, when possible I'd trim it down below 10mV. In direct coupled power amps there is always a small DC offset, it's just a matter of it being acceptibly low. To get zero is unlikely, nay near impossible! Unless you put a dirty (and likely sounding that way) big electrolytic cap there and no DC... oh the leak at bit, don't they? The whole idea of direct coupling circuits was getting rid of that cap in the first place, because from early on it was considered undesirable.
So what is the effect of the 21mV?
Assuming, in your case, near worse case scenario, low 4 Ohm speakers, DCR of voice coil 3 Ohm, then 21mV:
(0.021/3)*0.021 = 0.000147W
So 147 microWatts dissipation in the voice coil, and even much less than 100uW with 8 Ohm speakers. I would'nt loose much sleep over that and neither should the good professor.
Happy listening.
Joe R.
PS: Would you be game enough to print this out and show it to your professor. It could be interesting to know his reaction?
Now I don't want to be insulting my professor, perhaps he did not know that it was an audio amplifier. all I asked was what to do about 21 mV of DC in the output. so probably MY mistake in not being clear.
not yet, maybe tomorrow. maybe not, if it is acceptable as it is
as for the 147uW, DANGIT. I should have been able to figure that out. It never occured to me that the things we learned last semester have relevence in the real world.
thank you for the help, I will post more pictures as I am finishing the cases soon.
NUUK.
Yes, I agree with the straight wire bit, I've just tried it.
Do you think there's anything to be gained by adding a second transformer. ie. one per channel. I already have one thats identical to the first one. If so would I need to increase the fuse rating?
Regards Al
Al, I have had excellent results with just a single (single bridge) power supply but as a rule I use dual mono PSU's (single bridges but separate transformers).
As ever the motto is 'suck it and see' ;)
here is the GC in an almost finished state. I moved the power supply to a seperate enclosure, and doubled up the base plate to let me hide the wiring. next is a top and sides (removeable) with a window made of acrylic set into the top so I can show off the red glow and the wire job.
I like the idea of having our handywork exposed - at least some of it as I think the wiring is a bit unsightly.
And using a two layer base is a good way of hiding wiring as Aunkst shows us. building up a case from layers in this way is also a relatively easy way of building a nice case and of course we don't have to stick to the rectangular shape either :smash:
