My "audiophile" LM3886 approach
Joined 2013
Shorted with a 470-ohm resistor and no hum on that channel.
Also check the RCA's and they are isolated from the chassis.
I've seen where some put a zobel at the input, would that be the next thing to try? If so what values for the Cap and Resistor?
Edit-also same offset with and w/o the input shorted -3mV right and -1mV on left channel.
Let warm up.
I have built a few versions. They seem to sound a little better after being powered up for a while. Overnight is great but I think a hour or so is also good.
The 1 - 3 mV dc offset is also fine. Try measuring the AC voltage. This is your hum. The layout of the wiring will make a difference.
Look at Mauro’s orginal wiring diagram. It is shown in the build sheets. He was very detailed here. This was to minimize hum pickup from power transformer leads.
Lastly he did not recommend using over 0.33 ufd for the input coupling cap. Said it could lead to low frequency instability. Lectured me several times on this. I replaced my 1 ufd caps with 0.47 ufd to make sure.
Now use a four channel system and crossover at 65 Hz so this may not be a factor. Helps with the power output limitations also.
I think you meant to write less than 0.33. Larger than 1.5 will yield no sonic improvement. Less than 0.33 will affect low frequency, unless that's what you want to do.
In my amps, I use a .022uf input cap and 18k R13 as a passive 6db high pass crossover at 400Hz, which works very well.
Peace,
Tom E
Joined 2013
Ran a few more tests and I'm still perplexed by my findings.
Both RCA's plugged in - no hum
both RCA's unplugged - hum
either RCA plugged in - no hum
It is certainly AC type hum - measuring 0.002 on Left channel input and 0.006 on right channel input.
Is it possible it is picking up transformer hum? Should I try a shielded cable and see if that helps?
Also see a lot of people (Rev D version) that uses a CL60 on teh PGND connection. Would that do anything?
It'a annoying and I want to try and figure out why the hum is there, as much for learning as just to have a quiet amp at all times.
an open interconnect attached to an input becomes an aerial feeding the Rin resistance.
That will pick up a lot of interference.
Short the far end of that interconnect and now the amp input sees the short as it's input load and the noise pickup is very much reduced.
Question,
do you ever listen to audio files with the interconnect open ended?
Now to your non results:
what is the AC voltage on the amp output when you short the inputs with dummy zero ohms plugs? measure using a DMM that has a resolution of at least 0.1mVac
what is the AC voltage when you fit one long interconnect with an open end. measure both output channels.
what is the AC voltage when you fit two long interconnects both with open ends.
Short the barrel/outers together at the open ends. Short the inner to the outer of both interconnects. Measure the AC voltage.
short the inners to the outers, leave the barrels/outers not connected. measure the AC voltage
Trying to measure 0.001Vac on a scale with a resolution of 0.001Vac is nearly impossible. Read your instruction booklet. The final digit has a tolerance of typically +-0.5% of reading PLUS 2 or 3 digits.
To put this in perspective, EVERY MyRef amp ever built hums with open inputs. If the hum bothers you while listening to your system with no inputs, ;) just turn it off. No more hum.
Peace,
Tom E
Reactions: 1 user
Joined 2013
I get it, I'm being stupid...but I thought I read every page of this and the 4 other My Ref threads and never saw a single mention of this type of humming. Granted who would judge hum with an open input as a problem except me.
OCD is a disease and not understanding "why" makes it twice as irritating to my brain.
I will stop trying to figure out why and enjoy what I have when the inputs are plugged and the music is playing.
Or use the cap as the first one pole stage of a multi-pole filter.
If you have a natural roll-off that is at the correct frequency and is 2pole and you want 4 pole at that same frequency then you could use the capacitor to add one pole passively and add in a second one pole active but with a Q = 1 so that you end up with a Butterworth 4pole acoustic roll-off.
But it's much better to have an octave spare in the natural roll-off and then you have a 3pole active with Q=1 and the passive 1pole from the capacitor. This gives a cleaner performance at the turn-over frequency.
But that active 3pole may need to be shelved into a 1pole, where it reaches the natural roll-off of the driver.
My speaker protection isn't kicking in. I just noticed a DC offset of around 10V because R43 (Rev C) was 22M ohms. Although I've fixed it and there's acceptable DC offset now. One day the old speaker cables just shorted when I was twisting them straight. The 200w bulb in series went very bright for some seconds when I just turned the thing off and fixed the wires before powering on.
I think rev C has slightly modified values of the protection circuit than A. Attached are schematics and Mauro's inputs.
What's the right way to troubleshoot.
Included:
1. Original schematic
2. rev C.
3. rev A (improved speaker protection that everyone is supposed to be using in the latest version / kit ? )
The Voltage +VRL it's about +24V.
At start up C12 it' s discharge and determined (with R14 charge current) the ON-time delay. At VB Q1 >1,2V the darlington (Q1&Q2) close the Output relay.
If at Ampli out it's present a positive tension with time- costant > several mS (integrated on C19-R42 or R41) and Voltage > 2V (about),
Q3 discharge C12 and Relay are Open. If the status return at 0VDC, C12 are recharge with delay.
If a negative tension are present at ampli out, C12 it's discarge (from R44 or R43 and Q1 base potential are about 0V (or some negative mV) so, Relay it's off.
The Low value of C13 disable immediately the relay on power off state.
Ciao
Mauro
Hi, Greg
Your observation is near, but...:cool:
My description is a lot of fast, and non exact (sorry). With the components used in the circuit the threshold of intervention is +5,5VDC @ 0 , 5 sec. and -5, 5V @ 2 sec. The motive is that C12 discharge of 0,3V to stop the relay. Naturally modifying R44 R43 R42 R43 gets the constant and the threshold that is prefered.
Affair remembers that the speed of various intervention to the increase of the tension, and if an ending is spoiled usually in exit there are about tens of volt. In this conditions the intervention becomes < 0,5 sec. even on the negative thing.
Obviously this circuit not doesn't want be an absolute reference, and it is in my scheme because much compacts ( all the circuit is on a 100160mm card ). In the use daily paper has not given never problems and the breakdowns of the prototypes have not damaged never my loudspeakers.
Ciao
Mauro
  • my_ampli.pdf
  • revc.pdf
  • reva.pdf
