I finished assembling my RevC boards and began testing them today. They seem to work fine so far. I thought the LM3886 would get much warmer than it does, but it stays only moderately warm. However, I am surprised at how warm the 1k ohm resistors get on the board. Is this normal? I now understand the importance of keeping these resistors elevated above the board.
Although I haven't sat down to critically listen to the amps, I like what I hear. It's pretty gratifying listening to something you made--even if it was just soldering a kit together.
Now, on to the metal casework... (pictures forthcoming)
orthoefer said:However, I am surprised at how warm the 1k ohm resistors get on the board. Is this normal?
Those 1K resistors supply the shunt regulator (the resistors plus the zeners) so they are passing a lot of current. It is quite normal for them to stay fairly warm(yes even hot). They will be dissipating around a watt each.
Cheers!
Russ
Provided we get kits to buildI know you will enjoy it, and I bet it's not the last audio component you will make
Seriously, this inexpensive and easy to build project brings world class sound but promotes DIYer lazyness I mean, why stress further?
M
I couldn't agree with you more.
I've just designed a PCB layout for a simple but very good MC Head Amp ( by Marshall Leach, Jnr.) Granted I am a tad fussy, but it took me an age to do with graph paper. Making the PCB will no doubt take an age as well, and will be inferior to a professional job, such the excellent Twisted Pear boards.
Audie.
Cheers!
Russ
I didn't assemble my resisters off the board. Am I going to run into problems? Should I consider replacing them. I have my boards built, but I haven't powered them up yet.
(K)
(K)
You will probably be fine even with them mounted on the PCB. It is better for them to be lifted 1/2" or so, but it will probably not kill them if they get a bit warmer than usual. I would replace them when you can, but you could run them this way for quite a while, really probably indefinitely.
Yes. I'll send you a replacement set.
Humming
I finally completed one channel of my RevC. Powered up without a hitch, relay clicked, etc.
When I connect my test speaker, a *very* noticeable hum starts. I rechecked the connections, moved the trafo around, and changed the input polarity (now the center lead of the RCA goes to the ground input, I suppose that's wrong).
Now the hum is much lower, but the volume is low too.
If I touch the center RCA lead, the hum becomes unnoticeable, and the volume lowers.
If I touch the outer lead, the humming and the volume increases.
Any tips?
Any tips?
I got the full kit from http://www.twistedpearaudio.com/. Excellent quality. They seem to be temporarily out of stock now.
Hi destroyo
Please check out if your signal ground is connected to chassis: it must not.
Also, power ground goes to PCB only, not chassis.
Excuses if this is all known
Buena suerte!
Mauricio
PS: if it still does humm, check your preamp grounding.
PS2:
Buena suerte!
Mauricio
PS2:
Yeah! Why do you guys are sooo cruel!They seem to be temporarily out of stock now.
Is your mains ground connected to the circuit? It shoudl not be.
Not now. Only did it for a small test (to the ground input).
- Chip Amps
- My "audiophile" LM3886 approach
