Have you replaced the 5532 nearest the 3120s after the last failure of the 15v regulator?
The input offset is a bit more than I'd expect. It may be OK if the amp was oscillating but I'd expect it to be closer with no oscillation.
Connect a load to the speaker terminals and post the DC voltage on pins 5, 6 and 7 of the 5532 nearest the 3120s.
Confirm that the voltage without the load is the same as the voltages you previously posted for pins 5, 6 and 7.
- General Interest
- Car Audio
- MTX 81001
