If the regulator failed, it's possible that the op-amps were damaged. The 10 ohm resistors near the RCA op-amp should protect the regulator if that op-amp is defective but I don't think there is anything to protect the regulator if the other two op-amps are defective. Replacing them would probably be best.
- General Interest
- Car Audio
- MTX 81001
