O.k. here it isone 'Transresistance CFB BIGBT Amp, By FdW'
Yesterday it reached a new milestone, the 4AmpT net fuses where blown (several times). Extensive measuring and testing found nothing wrong, the amp was consuming 900Watt per channel and delivering (about) 600Watts per channel to the 'Carver Amazing, Platinum Edition's (loudspeaker panels), it was party time
Wow, you are an inventor of words. Modulating into the darkness.https://ia801702.us.archive.org/15/...s and Low-Pass Amplifier Design (1968)-RR.pdf
Yesterday it reached a new milestone, the 4AmpT net fuses where blown (several times). Extensive measuring and testing found nothing wrong, the amp was consuming 900Watt per channel and delivering (about) 600Watts per channel to the 'Carver Amazing, Platinum Edition's (loudspeaker panels), it was party time![]()
Impressive... congratulations... wish I was there.
Also really impressive.
This looks like a fun project :http://www.audiodesignguide.com/full/conus1.html
I ones had a pair of Ohm F.
They where eating power like crazy and sounded a bit dark.
But the bass and 3D space where amazing.
Due to a unfortunate event some days ago involving my bicycle and a dog I'm more or less immobilized and have bitten my way through this whole thread from where I once left it.
Wow!
The SE-Fet/folded-cascode input has been discussed ten years ago around here.
The second stage was with opamps, though. I build a few versions, it sounds promising, albeit I did not manage to get stable DC-conditions (this with a 9V-Block and a psu for the opamp-part). If I would do it again, I'd feed a CCS for the cascode-Q with a separate negative supply.
Or, if I'd been into tubes, build it with a p-fet input and fold-cascode it with a tube. This would give me some voltage swing to burn in a shunt riaa network.
Maybe, if my immobilization persists during next week my bench finds me sitting at it since a long time... (I can sit well, but not stand up (ough) or walk around (ooough))![yinyang :yinyang: :yinyang:](https://files.diyaudio.com/forums/images/smilies/yinyang.gif)
Rüdiger
Wow!
Rüdiger
Have you seen the circuit that the always interesting JC Morrison published on his blog a few years ago hybrid folded cascode Gm amp | lab jc.If I would do it again, I'd feed a CCS for the cascode-Q with a separate negative supply.
It sounds almost exactly like what you're describing. I attached a copy of the circuit to make viewing it a bit simpler. I haven't built it but it looks very interesting.
---Gary
No DC blocking cap at the output? Weaponized phono gain stage?
Luckily the output is marked 120V you are warned (that what you get when SDI is scraped and these 'engineers' get a new job).
https://www.google.com/search?q=sdi...CLyQOF1oD4BA&ved=0CAgQ_AUoAw&biw=1496&bih=925
p.s. I see 16mA is also marked, this most be a killer app.
Now to find a realistic spice model of a D3a, or, better yet, some unknown russian tube that sells for a few pennies...
Ale (mogliaa on this site) has done a nice comparison of quite a few Russian tubes to the D3A. Take a look here: http://www.bartola.co.uk/valves/2013/02/23/russian-pentodes-in-triode-mode/
---Gary
