MPP
I have the Atlas playing now.
Lyras are known for the speed, resolution and air they command and the Atlas has that in spades. But that is not what really surprised me. The tone it has contains a power and fullness that sounds like the real thing. There is absolutely no brightness, spit or harshness. The bass goes down very deep and is powerful.
I had to lower the volume on my sub a bit and play with the crossover frequency to my Enviee drivers. Ones adjusted the bass shows great ability to differentiate. The Atlas puts out a healthy volume so i get a very dynamic and loud sound without cranking my preamp much.
I heard many great cartridges but i have to agree with most that heard it :
This is one of the finest cartridges out there, maybe the finest.
I have absolutely no complain.
Is this measured resonance or subjective impression?
Never had one but have enjoyed the reviews and the super adjustments that every arm should have available like this one.
The new 12" Triplanar had to keep the effective arm mass down and went to carbon fiber, but is still slightly heavier.
Not sure if Cf will be the band aid needed and how they suppress those out in the end.
Interesting times with vinyl now!
David
The major flaw of the Wheaton is a beam resonance at ca.300Hz.
I think that gives it this robust tone..............
Thank you for that Joachim as it may explain a problem I had a few years ago.
I used a Tri-PLanar MKIV (the first fat tube one) with SPU and Io cartridges. The bearings would unlock after about an hour. I knew that those cartridges were producing a lot of mechanical energy and maybe the beam resonance hastened the un-screwing of the bearings? I went back to a Zeta and a heavy unipivot. But, when all was well the Wheaton was very good.
I got a Quantum Asylum Audio Analyzer.
I made a loop back measurement and got the 3rd harmonic at ca.-105dB. That is around 10dB worse then Audio Precission teritory but 10dB better then i get with my E-MU 0202USB so i think this is usefull.
Just for fun i measured the B1 buffer i build quite a long time ago.
At ca 1.3V RMS ( around 4V P-P ) i get around -95dB distortion. I think for something so simple this is very good. I also show distortion at lower volume and the volume where the third disappeares in the noise. The first picture is a loop back measurement of the analyzer.
The last picture is intermodulation with a 10kHz -10dB sine mixed in.
If i had one in isolation, yes.
I have it on the XEN ESS board and on the Paradise.
We simulated it though and it has ( much ) lower distortion provided it is not driven out of class A or voltage overdriven.
I can make an even better buffer especially if more voltage and current is needed.
The attractive thing with the BF862 based version is the extreme compactness.
Concerning measurements, an AD797 buffer with common mode compensation would have no measurable distortion, even on an AP. Does it sound better ?
I think the success, subjectively, of my buffer-filter is the extreme simplicity combined with the good performance.
I do not think that static distortion measurements tell us all about the sound.
I wish it would be that easy.
Joined 2010
I am fully aware of the fact that good numbers do not necessarily correlate with good sound. I just wanted to get an idea of the measured performance of the buffer.
I was too lazy to simulate it on my own. If I would have done it, I would have seen that the buffers distortion figures will probably not be measurable with the given equipment:D Just found the thread from calvin about preamp buffers with simulation results.
The subjectively perceived quality I know very well ;)
