MPP
mkc
Joined 2002
A problem with ksa1381 ksc3503 is that at this moment, there is only avaiable the hfe group D for the npn and the hfe goup E for the pnp, I will buy some for the amplifier that i am developing , and then I will do some measurements. But i will for shure use them as pré-drivers.
For ksa1381 ksc3503 in E-group (if my memory doesn't fail me) you might want to look up Sonnya here on diyaudio. He might be able to help you.
Mogens
Here are the Sanyos, E group, certainly the PNP has no problem with early effect. The last 3 lines show the cluttering i taked about. Just ignore the non straight lines.
I hope this bug will be eroded in future software updates.
The next two are 2SJ74BL and 2SK170BL. the 2SJ has 10mA Idss, the 2SK has 8mA Idss.
The last picture shows 2SJ 10mA, 2SK 8ma and last 2SJ 8mA.
Sorry JJ506, i do not know you and my source has only a few for prototypes anyway.
So far i did not test the KSC, KSA, only original Sanyo.
You are in the far east and get them more easy than i do.
diyAudio Chief Moderator
Joined 2002
Got a bunch of 2N4401 / 03s made by ROHM Japan which track very near each other as they come on ammo tape. They average 150 hfe at 2.5mA. My 2SA1015GR 2SC1815GR hit 220 plus though and are low enough Rbb (4401 territory). Another curve match test candidate pair.
The yellow graph is a 2SJ74 with a little less Idss then the green graph 2SK170 so part of the missmatch comes from the Idss difference. On the other hand you can see that the yellow curve has a steeper bend. 2SJ74 have higher Gm with the same amount of idle then the 2SK170.
From graph 3 post 8266 you see that the 2SK170 needs less Vds to go into saturation.
That will allow the 2SK170 to work on a voltage as low as 3V to be linear.
Today i measured 2SA1015GR, 2SC1815GR and the 2SA970GR, 2SC2240GR pair.
The 2SA1015, 2SC1815 are good to about 6mA so somewhat better then 2N4401, 4403.
The 2SA970, 2SC2240 is really awesome. Very nice up to 12V, the maximum i can measure.
See the curves of the PNP 2SA970. Very high early voltage. That is the major problem in PNP but here it is fine.
I would say that the good reputation of Japanese audio transistors compared to the European counterparts is deserved, at least at high current.
The picture is taken with the snipping tool. Thanks Frans for that idea.
I had something called Snaggit some years ago that did the same but now that feature comes for free with newer versions of windows.
I measured some more candidates. The Zetex medium power SMDs do well up to 7mA. The picture shows the PNP, always the achilles heel.
I have also a surprising find : our old BC140, BC160.
Very high early voltage on the PNP and very symmetrical.
Actually here i did a little trick. The PNP had Hfe of 170 and the NPN over 300 so i adjusted the base current until they match. With this trick you can cancel distortion when the values are known. Matched for Hfe this gives a very good pair. I know from the 80th that they have decent low Rbb´too. Grundig used them in their MC heads, so did Stan Curtis and a friend of mine, a physicist. Some selection for noise is necessary here. I know that from the physicist so they do not come easy but when they play, they play just fine.
