Morgan Jones' RIAA Pre-Amp
I wonder if anyone can assist me. I'm starting to put together the RIAA pre-amp covered in MJ's Valve Amplifier book (3rd edition) (Figure 7.27 on page 543). I have started right at the beginning by running the calculations for my particular phono cartridge and that is where I've hit a problem. The basic issue is that when calculating the frequency response of the cartridge and valve input combination I end up with a -3db point at approx 17.7kHz. This is way lower than what I want (I want it to be well above 20kHz) and I don't know if I'm doing something wrong. For example, the equivalent circuit that I'm using might be incorrect or the formulae might be wrong etc. I've attached a PDF that shows the cartridge parameters, equivalent circuit, formulae and plotted frequency response. I would really appreciate it if someone on this forum who has some spare time to look over what I'm doing and offer any advice.
Many thanks.
  • AudioPreAmp.pdf
Many thanks.
No, you're not doing anything wrong, and the formulae you are using appear to be correct.
The response you are seeing is simply a consequence of running a source with fairly high inductance into a lowish load resistance. The high load capacitance doesn't help either.
If you re-run your analysis using 60k and 100pF as the load elements, you will see that (up to 20kHz) a much flatter response is obtained. In practice it is not hard to achieve such values. The unanswered question is - would you want to?
The peaked response and vigorous roll-off seen with 47k/250pF loading may well be intended to complement a non-flat response from the pickup. However, it seems fair to assume that a higher-quality MM cartridges will generally have a reasonably flat internal response, and will therefore probably benefit from loading with a higher resistance and lower capacitance than the 'traditional' values. Certainly it can't hurt - and it is a simple procedure to add parallel resistors and capacitors if you subsequently want to change the pickup loading.
