Re: Assistants
I just learn a little VHDL (1st year Electronic Engineering Student). Nice cats.
James
John Hope said:Here is a picture of my two (tax deductible) assistants.
I call them VHDL and Verilog.
James
It will go up.
Fridges only move head from one place to another. They also add a little heat of their own. Also, the light in the fridge will add more.
Now, if the room was at 0c, and the bulb had blown, the temp would stay constant.
Of course, there ain't no such thing as dragon...sorry... perfectly insulated rooms.
How is this humour?
James
How is this humour?
James
Cal Weldon said:Question:
Start with a perfectly insulated room, temperature at 20C. Add a running refrigerator with the door open, what will happen to the temperature in the room and why?
The plane would take off!!!
The room gets warmer. Second Law.
No, it still goes up. Second Law.
If it's in my house the beer will disappear first, followed by the Velveeta Cheese, nacho dip, pickled herring, olives ...the room will fill with hydrogen sulfide, methane and other olfactorily offensive molecules...
If the fridge was off in the room, temperature would stay the same....
Power it on
I suspect the heat produced by the motors will add heat.
The cooling elements will try to take some heat from the room (door is open) and then dump it back into the room (inneficiently, but I suspect more efficiently than the process on the coling side)..
So there should be a net gain of temperature...
Even if it was just a fan, the temp would go up, because there is a net increase of energy in the room... through the AC cable
Power it on
Fridge - continued
In South Africa the following will likely take place:
1. The fridge won't work because the power has been cut off most of the day for 'Load Shedding'.
2. The room will lose its insulative properties because people from the 'informal settlements'.will steal 90% of the insulating material to line their shacks. What's left will be pinched by management to use as sound deadening material in the speakers they are building.
3. The insurance weasels won't pay for the spoiled food in the freezer.
4. The plane won't be able to take off because it's broken.
In England the following will likely take place:
1. The fridge will be confiscated by the Dept of the Environment on the grounsds that it's causing degeneration of the ozone layer.
2. The room will lose its perfect insulative properties because Health and Safety Executive have banned the use of the insulating material on the grounds that it has been found to cause cancer in 0.1% of stillborn orang-utangs.
3. The evil insurance weasels won't pay for the spoiled food in the freezer.
4. The plane won't be able to take off because the airport personnel are on strike.
Let's hear it from your part of the world, people. . . .
SY said:The room gets warmer. Second Law.
My assumption was that if the room is at 0C, the fridge won't be running, therefore no energy will be transferred to heat.
Unless the thermostat/mains filter capacitor draws current, in which case it will rise.
James
Nordic said:What is so significant about 0C? it is not 0K or even 0F...
Just below the cut-in point of the fridge's thermostat, that's all.
jrevillug said:How is this humour?
Just read the above answers.
You guys are great.
gmphadte said:It's like.....
Can u throw an egg on a concrete floor without breaking it?
Gajanan Phadte
Is it perfectly insulated?
gmphadte said:Can u throw an egg on a concrete floor without breaking it?
Yes
- Member Areas
- The Lounge
- More engineering humor
