Hello,
i have installed the newest version of moode.
When Ethernet is connected, everything works just fine.
But when i diconnect Ethernet, reboot the PI with the PI Display, i the chromium Browser starts up, but in the Playback Tab i could only see a white Scrren in the middle with light grey buttons.
If i connect a Tablet over Wifi, the Webside is normal to see, but not on the PI Display itself.
MPD seems to work, the music plays normal after the Reboot.
Nothing helps here, no reboot, nothing.
What could be the Problem.
I want to use it only with wifi, so no ethernet needed.
If i press on browse, sometimes the middle part of tghe display comes back, but from 10 tests, only 2 times.
Any Ideas what i can do?
Best regards, Mirko
Hi Mirko,
try iwconfig command and see what the WiFi signal looks like
Example from my Pi-Touch, Pi-3B, Edimax 7811Un
Code:
pi@rp5:~ $ iwconfig
Ethan no wireless extensions.
wlan0 IEEE 802.11bgn ESSID:"AirnetN2" Nickname:"<WIFI@REALTEK>"
Mode:Managed Frequency:2.412 GHz Access Point: 60:45:CB:B1:CB:78
Bit Rate:150 Mb/s Sensitivity:0/0
Retry:off RTS thr:off Fragment thr:off
Power Management:off
[COLOR="Red"]Link Quality=100/100 Signal level=95/100 Noise level=0/100[/COLOR]
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
lo no wireless extensions.
pi@rp5:~ $
-Tim
I'm running moode4.0 on Pi2b+iqaudioDac+ and Pi3+IqaudioDac+
On both systems I have a "pop"-Noice on every skip to the next/previous" playlistentry (mpc play next etc.). (BTW: one of my amps is able to suppress the Nois; on Headphone i can hear it ever - even on my other amp). The noise ist independend of the volume (Volumecontrol set to hardware in mpd-settings).
Anyone with the same Problem?
Any idea for a solution?
Maybe Pulseaudio?
Audio information
INPUT PROCESSING
Source: http://ndr-ndr2-niedersachsen.cast.addradio.de/ndr/ndr2/niedersachsen/mp3/128/stream.mp3
Encoded at: VBR compression
Decoded to: 24 bit, 44.1 kHz, Stereo
Rate: 128 kbps
DSP OPERATIONS
Resampling: off
Crossfeed: off
Equalizer: Graphic EQ: (off), Parametric EQ: (off}
Crossfade: 0 seconds
Other: Volume normalize (no}, Replaygain (off)
Chip options: FIR interpolation with de-emphasis, gain=0 dB, boost=.8 dB
Volume ctl: Hardware (on-chip volume controller)
OUTPUT STREAM
Format: 24 bit, 44.1 kHz, Stereo
Rate: 2.117 mbps
AUDIO DEVICE
Device: IQaudIO Pi-DAC+
Chip: Burr Brown PCM5122
Architecture: Sigma/Delta Advanced Segment 24 bit 192 kHz
Interface: I2S
Any thoughts welcome.
yeah it only works on one of mine, I still get the pop when it starts, but you can skip tracks etc with no pops.
it's a hardware/driver issue on those cards as it does it no matter what the os/player is.
I do notice it is worse on pi3.
I agree it certainly seems like a hardware/chip issue. All my PCM5xxx boards have the "bump" but my Mambo LS and BerryNOS (TDA1543) boards are totally glitch free. Don't know if there is any way to compensate for this in MPD but it might be a good question for MaxK.
It happens when manually changing tracks but not when not when tracks transition automatically within playlist.
The link below has some info on the issue.
Click/Pop/Crack when changing tracks : Raspberry Pi • RuneAudio Forum
-Tim
Hi Tim,
here is the reault of iwconfig on my PI:
/var/log$ iwconfig
eth0 no wireless extensions.
wlan0 IEEE 802.11 Mode:Master Tx-Power=31 dBm
Retry short limit:7 RTS thrff Fragment thrff
Power Managementn
But i Think, it is a booting Problem, when i look in the moode.log, i could see, that it took a long time to start the mpd. service.
I tested it in the last few hours and it looks like, right after the Wlan goes online, i could make a refresh on the PI screen and the Display is OK.
So the screen comes to early i would, is this possible?
Best Regards, Mirko
/var/log$ iwconfig
Power Managementn
Code:
20180218 133915 worker: - Start
20180218 133916 worker: Successfully daemonized
20180218 133916 worker: - Init
20180218 133916 worker: Session loaded
20180218 133916 worker: Debug logging (off)
20180218 133922 worker: Host (SQPi)
20180218 133922 worker: Hdwr (Pi-3B 1GB v1.2)
20180218 133922 worker: Arch (armv7l)
20180218 133922 worker: Kver (4.9.79-v7+)
20180218 133922 worker: Ktyp (Standard)
20180218 133922 worker: Gov (performance)
20180218 133922 worker: Rel (Moode 4.0 2018-01-26)
20180218 133922 worker: Upd (None)
20180218 133922 worker: MPD (0.20.12)
20180218 133922 worker: USB boot not enabled yet
20180218 133922 worker: File system expanded
20180218 133922 worker: HDMI port off
20180218 133923 worker: File check ok
20180218 133923 worker: - Network
20180218 133923 worker: eth0 exists
20180218 133923 worker: eth0 address not assigned
20180218 133923 worker: wlan0 exists
20180218 133923 worker: wlan0 SSID is blank
20180218 133923 worker: wlan0 AP mode started
20180218 133940 command/moode: Connection to MPD failed
20180218 133942 command/moode: Connection to MPD failed
20180218 133955 worker: wlan0 wait 0 for IP address
20180218 133959 worker: wlan0 wait 1 for IP address
20180218 134002 worker: wlan0 (172.24.1.1)
20180218 134002 worker: - Audio
20180218 134002 worker: ALSA outputs unmuted
20180218 134002 worker: Audio out (I2S audio device)
20180218 134002 worker: Audio dev (HiFiBerry Digi+ Pro)
20180218 134002 worker: ALSA mixer name (Digital)
20180218 134002 worker: MPD volume control (disabled)
20180218 134002 worker: Hdwr volume controller not detected
20180218 134002 worker: - Services
20180218 134004 worker: MPD started
20180218 134004 worker: MPD scheduler policy (time-share)
20180218 134004 worker: MPD output 1 ALSA default (on)
20180218 134004 worker: MPD output 2 ALSA crossfeed (off)
20180218 134004 worker: MPD output 3 ALSA parametric eq (off)
20180218 134004 worker: MPD output 4 ALSA graphic eq (off)
20180218 134004 worker: MPD crossfade (off)
20180218 134004 worker: - Last
20180218 134004 worker: USB sources (THE-STICK)
20180218 134004 worker: NAS sources (mountall initiated)
20180218 134004 worker: Volume level (0) restored
20180218 134004 worker: Auto-playing id (11)
20180218 134004 worker: Maintenance interval (21600)
20180218 134004 worker: Watchdog started
20180218 134004 worker: Ready
Best Regards, Mirko
I only have this problem with the combination of IQaudIO Pi-DAC+ and Pi-AMP+.I agree it certainly seems like a hardware/chip issue. All my PCM5xxx boards have the "bump" but my Mambo LS and BerryNOS (TDA1543) boards are totally glitch free. Don't know if there is any way to compensate for this in MPD but it might be a good question for MaxK.
-Tim
All the other boards(Pi-DigiAMP+, Pi-DAC PRO, Pi-DAC+, Pi-DACZero and Pi-Digi+)I have are glitch free.
Below is the answer from Gordon when I asked about the problem.
"This has been seen with various files where the audio format changes.
Depending on the file being played you may find that altering the auto mute in alsamixer has an effect."
Janne
Finally got around to installing MoOde 4.0 on a PI3 with a HiFiberry DAC this afternoon. All I can say is "WOW" donation sent. GUI is vastly improved over 3.x.
Not sure whom is responsible for the 4.0 install/build script. Thank you, everything went without a hitch.
Great Work!
Great Work!
Hi Tim,
/var/log$ iwconfig
Power Managementn
Code:20180218 133915 worker: - Start 20180218 133916 worker: Successfully daemonized 20180218 133916 worker: - Init 20180218 133916 worker: Session loaded 20180218 133916 worker: Debug logging (off) 20180218 133922 worker: Host (SQPi) 20180218 133922 worker: Hdwr (Pi-3B 1GB v1.2) 20180218 133922 worker: Arch (armv7l) 20180218 133922 worker: Kver (4.9.79-v7+) 20180218 133922 worker: Ktyp (Standard) 20180218 133922 worker: Gov (performance) 20180218 133922 worker: Rel (Moode 4.0 2018-01-26) 20180218 133922 worker: Upd (None) 20180218 133922 worker: MPD (0.20.12) 20180218 133922 worker: USB boot not enabled yet 20180218 133922 worker: File system expanded 20180218 133922 worker: HDMI port off 20180218 133923 worker: File check ok 20180218 133923 worker: - Network 20180218 133923 worker: eth0 exists 20180218 133923 worker: eth0 address not assigned 20180218 133923 worker: wlan0 exists 20180218 133923 worker: wlan0 SSID is blank 20180218 133923 worker: wlan0 AP mode started 20180218 133940 command/moode: Connection to MPD failed 20180218 133942 command/moode: Connection to MPD failed 20180218 133955 worker: wlan0 wait 0 for IP address 20180218 133959 worker: wlan0 wait 1 for IP address 20180218 134002 worker: wlan0 (172.24.1.1) 20180218 134002 worker: - Audio 20180218 134002 worker: ALSA outputs unmuted 20180218 134002 worker: Audio out (I2S audio device) 20180218 134002 worker: Audio dev (HiFiBerry Digi+ Pro) 20180218 134002 worker: ALSA mixer name (Digital) 20180218 134002 worker: MPD volume control (disabled) 20180218 134002 worker: Hdwr volume controller not detected 20180218 134002 worker: - Services 20180218 134004 worker: MPD started 20180218 134004 worker: MPD scheduler policy (time-share) 20180218 134004 worker: MPD output 1 ALSA default (on) 20180218 134004 worker: MPD output 2 ALSA crossfeed (off) 20180218 134004 worker: MPD output 3 ALSA parametric eq (off) 20180218 134004 worker: MPD output 4 ALSA graphic eq (off) 20180218 134004 worker: MPD crossfade (off) 20180218 134004 worker: - Last 20180218 134004 worker: USB sources (THE-STICK) 20180218 134004 worker: NAS sources (mountall initiated) 20180218 134004 worker: Volume level (0) restored 20180218 134004 worker: Auto-playing id (11) 20180218 134004 worker: Maintenance interval (21600) 20180218 134004 worker: Watchdog started 20180218 134004 worker: Ready
Best Regards, Mirko
Hi Mirko,
Output from your ifconfig cmd does not look right. It should look like below showing SSID, access point MAC, Link qual, etc...
-Tim
Code:
pi@rp3:~ $ iwconfig
Link Quality=100/100 Signal level=97/100 Noise level=0/100
pi@rp3:~ $
Janne
Hi Janne,
Audio format or that odd alsa setting have never been attributed to this particular PCM5xxx glitch in my experience.
Its easy enough to reproduce but debugging would require expertise in the low-level functions of the audio device, ALSA API and MPD.
-Tim
Great Work!
Thanks go to @koda59 and @HeeBoo for the nice Builder, and to @swizzle for the new, modern UI with its extra nice Adaptive-ness
-Tim
Hi Mirko,
-Tim
Code:pi@rp3:~ $ iwconfig eth0 no wireless extensions. wlan0 IEEE 802.11bgn ESSID:"AirnetN2" Nickname:"<WIFI@REALTEK>" Mode:Managed Frequency:2.412 GHz Access Point: 60:45:CB:B1:CB:78 Bit Rate:150 Mb/s Sensitivity:0/0 Retry:off RTS thr:off Fragment thr:off Power Management:off Link Quality=100/100 Signal level=97/100 Noise level=0/100 Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0 Tx excessive retries:0 Invalid misc:0 Missed beacon:0 lo no wireless extensions. pi@rp3:~ $
Ummm, Tim, looks like @klicker09 is running an RPi3B in AP mode. Here's my output for same:
Code:
pi@moode-001:~ $ iwconfig
Retry short limit:7 RTS thr:off Fragment thr:off
Power Management:on
Same.
Regards,
Kent
Hi Kent,
I changed to AP mode on my Pi Touch and initially got the odd white panel but when I selected Refresh from the moOde menu all was good.
Could be a Chrome Browser cache thing --or-- maybe my results were successful due to the new nohook param in dhcpcd.conf thats part of moOde 41, hard to say.
-Tim
-Tim
About not mounting NAS, look via SSH if /mnt/NAS exists ?
If /mnt/NAS is not here, just type :
sudo mkdir /mnt/NAS
... and try again to mount it via UI
Very weird ... same problem on two different SD Cards
So I hoped that whatever glitch was keeping me from finishing a build was gone this morning. So, I tried again from scratch. I was patient and after a couple power cycle reboots, it finished without error and came up. I then logged in and enabled the iqaudio dac+ driver and rebooted. That came up fine. THen I tried to add my NAS shares (smb from freenas 11.0) and now it is locked up. I can SSH in, I can get the default web page, I select configuration, I select sources, but nothing happens. I can close the configuration window and go back to the default interface but cannot add my music files nor delete it. 'df' shows nothing mounted, dmesg shows no errors. /var/log/moodeaudio.log shows
Code:
20180218 212809 wrk_sourcemount(): Mount error: (username specified with no parameter)
I do not need a password to mount them in Rune nor from any of my Linux machines. What do I need to do to reset this?Code:... 20180218 212809 wrk_sourcemount(): Mount error: (username specified with no parameter)
Just enter a bogus userid and password for now, for example guest, guest.
Upcoming moOde 4.1 includes a Samba share scanner and much better input validation for example userid cannot be blank, friendly name cannot already exist, no leading slashes in server etc..
-Tim
Tim,
I cannot remove the mount point. I click confirm and It just hangs there. I can play internet radio, but cannot mount and play anything off my nas. I even tried to put in the runeaudio options "cache=none,noserverino,ro", and it does not stick. Is there a way to reset the database from the command line. The UI does not seem to respond. This is on a Pi3.
Keith
Keith
Hello Tim,
thanks for the Test.
This is the same thing i see.
When connected to ETH0 this dosnt happend, only when its in Wlan Only mode.
Normaly no refresh is needed.
When i look in the moode.log, i see that there is a Point where ETH0 is enabled.
But in the Settings, i have ETH0 disabled, this settings seems to take place a little bit later.
So the Chromium Browser is already running before ETH0 is disabled.
This could be the cause for this display Problem?
Best Regards, Mirko
Best Regards, Mirko
Hi Kent,
-Tim
For guys who suffer from samba issue with Moode 4.0 Newest kernel Linux moode 4.14.18-v7+ #1093 SMP Fri Feb 9 15:33:07 GMT 2018 armv7l GNU/Linux
Add to vers =2.0 to Mount flags = ro,dir_mode=0777,file_mode=0777,vers=2.0.
It depends on what is presenting the CIFS share.
In my case I needed both sec=ntlm and vers=1.0
No one size fits all.
Cheers.
Phil
Hi Kent,
Thanks for your answer!
I will build a fresh install tomorrow (to make sure everything is standard Moode 4.0) and will only use the internal audio output.
I'll keep you posted.
Hi Kent,
I installed a fresh Moode 4.0 without any modifications build and let it run for more then 24 hours using the internal audio output, no freezes.
After connecting the DAC, the Pi froze within an hour. Because I had a ssh session running I was able to capture the following messages:
pi@raspberrypi4:~ $
Message from syslogd@raspberrypi4 at Feb 17 18:16:08 ...
kernel:[ 984.173769] skbuff: skb_over_panic: text:8054f268 len:1526 put:1526 head:ac270440 data:ac270482 tail:0x705f6 end:0x222 dev:eth0
kernel:[ 984.178144] Internal error: Oops - BUG: 0 [#1] SMP ARM
kernel:[ 984.199867] Process swapper/0 (pid: 0, stack limit = 0x80c00210)
kernel:[ 984.201170] Stack: (0x80c01d48 to 0x80c02000)
kernel:[ 984.202462] 1d40: 000005f6 ac270440 ac270482 000705f6 00000222 b9558800
kernel:[ 984.205107] 1d60: 80c01d84 00000222 80c01d94 80c01d78 80618498 806167cc b9558d00 b9171f00
kernel:[ 984.207779] 1d80: adc286c0 00000000 80c01dbc 80c01d98 8054f268 80618444 60000113 00000000
kernel:[ 984.210447] 1da0: b9171f00 60000113 00000000 00000000 80c01ddc 80c01dc0 80559254 8054f240
kernel:[ 984.213143] 1dc0: b6414e80 b9171f00 b9171f00 00000000 80c01dfc 80c01de0 80559380 805591e0
kernel:[ 984.215975] 1de0: bab422d0 b6414e80 b9568000 b9171f00 80c01e24 80c01e00 80583408 80559340
kernel:[ 984.218935] 1e00: 80c01e44 20000113 804eda0c b94eb940 b94eb944 00000000 80c01e34 80c01e28
kernel:[ 984.222020] 1e20: 805924b8 805833a8 80c01e5c 80c01e38 80123138 805924a4 801230c4 80c02080
kernel:[ 984.225273] 1e40: 00000000 80c00020 00000100 b9c05180 80c01ec4 80c01e60 8010169c 801230d0
kernel:[ 984.228600] 1e60: 8017440c 8071bb84 00000001 00200100 80c02d00 00010b41 0000000a 80c7b980
kernel:[ 984.232008] 1e80: 80c72798 80c0312c 80b793b8 80c02080 80c01e60 00000001 801732e0 80b7cec4
kernel:[ 984.235475] 1ea0: 00000000 00000000 00000001 b9c05180 80c00000 babffa40 80c01ed4 80c01ec8
kernel:[ 984.238963] 1ec0: 80122ccc 8010151c 80c01efc 80c01ed8 80173910 80122bcc 80c01f18 80c04670
kernel:[ 984.242453] 1ee0: 60000013 ffffffff 80c01f4c 80c723fd 80c01f14 80c01f00 8010150c 801738ac
kernel:[ 984.245946] 1f00: 80c040a4 80108a58 80c01f74 80c01f18 8071c3bc 80101470 00000000 ba35c470
kernel:[ 984.249442] 1f20: 00000000 00000000 80c00000 80c0312c 00000001 80c03198 80c723fd 80c723fd
kernel:[ 984.252936] 1f40: babffa40 80c01f74 80c040a4 80c01f68 80108a54 80108a58 60000013 ffffffff
kernel:[ 984.256432] 1f60: 80108a54 00000000 80c01f84 80c01f78 8071bb14 80108a30 80c01f9c 80c01f88
kernel:[ 984.259928] 1f80: 80162020 8071baec 808023f0 ffffffff 80c01fac 80c01fa0 80716324 80161f48
kernel:[ 984.263424] 1fa0: 80c01ff4 80c01fb0 80b00d28 807162ac ffffffff ffffffff 00000000 80b006f8
kernel:[ 984.266921] 1fc0: 00000000 80b56a30 00000000 80c7b294 80c0311c 80b56a2c 80c089a8 0000406a
kernel:[ 984.270417] 1fe0: 410fd034 00000000 00000000 80c01ff8 0000807c 80b00980 00000000 00000000
kernel:[ 984.340488] Code: e58dc014 e58d500c e58d4010 ebefcea0 (e7f001f2)
Session stopped
These issues never happened on Moode 3.7, so at this moment I'm stuck on 3.7.
Is there anything left I can try regarding settings in the cmdline.txt /config.txt / kernel /drivers etc.?
Thanks and regards.
Spotify
Hi Tim,
They have fixed the initial volume - you can set the initial volume in the config now. Its 50% for standard (instead of the previously 100%)
Options * librespot-org/librespot Wiki * GitHub
Option
initial-volume
Initial volume in %, once connected [0-100]
VOLUME
Well sure, if u install something thats not included in moOde then of course altering the configs is usually necessary. I was referring to the configs that are managed by moOde.
Btw, moOde doesn't include Spotify Connect due to the 100% initial volume issue, but it looks like some devs have begun to work on librespot again so hopefully this will be fixed.
-Tim
Hi Tim,
Option
initial-volume
VOLUME
- PC Based
- Moode Audio Player for Raspberry Pi
