Hi tppc,
I haven't been following this thread lately, any news on the update for displaying file names for tracks which don't contain tags?
Should be working in 2.1. Give it a try
Regards,
Tim
Hi Markus,
Press the Playback tab a second time and the Playlist will auto-scroll to the currently playing song. Same for when Playlist is manually scrolled past currently playing song, just press the Playback tab.
Similarly, on a Smartphone when pressing the "open circle" header button to toggle between knobs and album art, pressing the Playback tab snaps back to the Playlist with auto-scroll to the currently playing song.
Regards,
Tim C
Thanks Tim,
I wasn't aware of that. Works great on my notebook as well as on my smartphone (iPhone 6).
But I don't see this "open circle" on my tablet (Nexus 7 2013) and clicking (again) on Playback doesn't show any effect at all.
Do I need to click somewhere else?
Tested the 2.1 version, the song title update is working great. But I still have a suggestion. It would be really really useful to also display the name of the containing directory instead of "Unknown artist - Unknown album". So if the file is located in ...\Some Artist - Some Album\Song.mp3, "Some Artist - Some Album" is displayed below "Song". Thanks again for this update.
Would it be possible for Moode to update the current playing song information via serial?
Artist, title, album/year, samplerate/bitrate
That way an arduino could pick up the data and drive a display.
I know the pi can drive a display but I already have an arduino for volume/channel switching which displays some info already and it would be nice to have it all on one screen.
Makes sense. I've added to my to-do list.
Tim
Most likely yes. Do u know of any existing code that can push text out the serial port?
Regards,
TimCurtis
Can Moode be installed on Odroid C1+ boards?
Most likely no. Unless the board can run stock Raspbian, then maybe
Regards,
Tim Curtis
How about this?
Welcome to pySerial?s documentation — pySerial 2.7 documentation
And this?
https://pypi.python.org/pypi/nanpy
And this?
Thanks.Hi,
Tim
I have some other suggestions that are related to the one above:
- I think the name of the containing directory should also be displayed below the file names for the search results in the "Browse" tab; think about the case when you have multiple issues of the same album, currently you can't quickly tell them apart
- an "Add whole containing dir" command for the right click menu would be nice
- as it is, the search feature seems a bit limited; if I have say ...\Artist - Album\Some Song.mp3 and I run a search for "Artist Album", nothing is returned; IMO it should work as "search for all containing words, regardless of order", looking in both the file name and the directory name; if I now run a search for "Artist Song" or "Album Some", nothing is returned
Interesting. I don't recall seeing Py on the distro however I did run across a PHP based serial interface (link below). Something PHP based would be the way to go but since I don't have an Arduino board, there is not much I can do.
Using PHP serial class with Arduino and Raspberry Pi — Fritz-Hut
Regards,
Tim Curtis
Regards,
Tim Curtis
I am no programmer but I don't think you need an arduino to know what to put in the script. If you want one just let me know.
Mpdlcd shows the data that I am looking for. So however mpdlcd gets its info, it needs a php-serial script that sends it down the serial interface when the data is refreshed, rather than to lcdproc, the lcd driver.
Thanks.
- as it is, the search feature seems a bit limited; if I have say ...\Artist - Album\Some Song.mp3 and I run a search for "Artist Album", nothing is returned; IMO it should work as "search for all containing wordless, regardless of order", looking in both the file name and the directory name; if I now run a search for "Artist Song" or "Album Some", nothing is returned
Added to my to-do list for investigation. Coding for tag-less collections is "going against the grain" of the existing tag based Player design don't u think? lol
TIMCurtis
I agree.
But I'm a rather change-reluctant personality Like I said, and please don't be offended because that's not my intention, I think foobar hits the spot in most aspects in regards to ergonomy and those are features that I had become accustomed to from the days when it ruled the world of audio players The 19th century I think? It's up to you if you decide to add those. I still think Moode is better than Volumio.
Not true (for me). If I were going to spend time on something like this for a Moode release I would want the hardware to test against. U suggesting that I just cook some code up and send files back and forth, no way.
However, I think your idea is a good one, to have a serial interface for song data built into the player.
Regards,
Tim Curtis
I agree.
Maybe u should tag your collection. There are utils that can probably do this automatically as a giant batch process while u chillout with a cold beverage.
Then all problems solved
Tim
- PC Based
- Moode Audio Player for Raspberry Pi
