Mini-Me phono preamp
B+ is about 150v, but between 120 and 160v will be good.(current 2.8mA).
This B+ comes from the MM section and is already very well filtered with CRCRCRCRC. If you only want to use the MC pre you need a good stabelized B+ and regulated heater supply.
Sorry i do not sell PCB's, but your free to use the PCB film design.
Ronny
Text in gold not in black.
The black text ones are rebranded 6H16-I types not as good.
That is the maximum distorsion of the generator.
Signal distorsion i do not know yet how to measure. Total harmonics distorsion i measured on the Mini-Me.You have to measure the harmonics from a 1khz sinewave, count and measure the harmonics from 0 to 20khz and then calculate the THD.If you have measure the noiseflloor then you also can calculate THD+N.
Picture below is a harmonics measurement.
