Mic, Line, EQ... Preamps
help me with this ML3
ML3 Schematic
Hi man i know its a bit late to quote this but ml3 that i have made is generating some noise when the vol is open.
espesialy it gets worse when i connect the mic to it.
what coul be the problem.
u know when mics coil is connected the noise is loud and when its not connected the noise is lower but suffering again. what to do man????:(
hi apex sir .
is this correct method for the tone control?
can i use 20k stereo controls, pls share if u have the pcb layout in pdf format
thanks.
