my smd ucd stero,up to1.2MHz pwm
i 'm from china, english not well
i have dev the smd ucd pcb, and drive the freq up to 1.2MHz
it can output a more sweet sine osc in 20K.
picture here:
http://www.class-d.net/UploadFiles/200718172817117.jpg
i'm thinking how to fix it to BTL, some body help
tks
picture here:
tks
here the link
http://www.class-d.net/UploadFiles/20071920500833.jpg
Baldin:
Sounds very interesting, but I can't seem to access the file!
Is the design based on the Philips App note?
How much power can it deliver
some diffrent with Philips App note,
base on it ,but we change something
we r trying to upgrade the power to 300~350WRMS
Baldin:
most mosfet can work on 1MHz
most mosfet can work on 1MHz perfect
u can read the datasheet, most of them were tested on 1Mhz
the correct type that i'm using ,i can't tell u sorry for that.
the hi-freq pwm,not just depend on fets,
the hold sch, the design of pcb,the return,etc..
a tips: look at class-d amp as a nomal amp...
i'll post the pic of freq-respont , plus-res, osc,etc..
perhaps,the pic of pcb
it is a hard work , because i'm not a full menber
i'm a newb here, and my english not well,
i dont(hard to ) understand the rules of this form
20khz square and sine
input 20khz square and sine (WAVETEK 271)
NOT SO MANY AMPs CAN DRIVER THE 20K so sharp
first time i use 400KHz pwm, the 20khz square just like 20khz sine
if down to below 400K, i cant except(can hear the diffrent)
i'm trying to build another d-amp up to 2MHz, trying
fumac,
Thanks for oscillograms
But am interesting measurements of perfomance, not the frequency response
A you doing measurements of distortion at 1khz sine??
like this:
http://www.diyaudio.com/forums/showthread.php?postid=1090535#post1090535
like this:
Bruno Putzeys Feind hört mit.
wellcome
but i dont konw what u say
Foxx510 Will you be selling these modules either in kit or completed form?
Adam
will be kit and completed
but i have no Interested to be a seller,
i'm finding PartnerS to sell it
callme skype:huygens_wireless
wellcome
Adam
- Vendor's Bazaar
- MHz class d amp
